DL650 '09 ABS brake bleed procedure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 15 Old 10-09-2011, 12:25 PM Thread Starter
GlenT's Avatar
I'm looking for (and not really finding) the official procedure for bleeding a 2009 with ABS brakes. I'd like to know if (for example) there are additional bleeders on the ABS unit, and in what order you need to bleed them.
In the BMW world, the procedure depends on the what generation of ABS your bike has. Some require powering the ABS unit. Wondering what the equivalent procedure is for this bike.
GlenT is offline
post #2 of 15 Old 10-09-2011, 12:49 PM
The procedure for bleeding ABS brakes is no different than the non ABS. The ABS supplement in the service manual just refers to the '04 manual for bleeding.
post #3 of 15 Old 10-09-2011, 03:21 PM Thread Starter
GlenT's Avatar
So, no additional bleed valves in the system?
2013 Tiger Explorer 1200
2009 DL650 ABS
2004 Honda ST1300
GlenT is offline
post #4 of 15 Old 10-09-2011, 03:44 PM
That's right.
redbirds likes this.
post #5 of 15 Old 10-09-2011, 04:11 PM Thread Starter
GlenT's Avatar
OK, thanks. I'll proceed as usual.
2009 DL650 ABS
2004 Honda ST1300
GlenT is offline
post #6 of 15 Old 10-12-2013, 05:08 PM
kiwi_outdoors's Avatar
bleeding ABS brakes
Did it go OK?
I need to rebuild my front calipers, and want to be prepared for bleeding an ABS Wee
kiwi_outdoors is offline
post #7 of 15 Old 10-13-2013, 01:39 PM
Keep in mind that if the vertical hose from the master cylinder to the caliper gets air in it, air bubbles rise, so it needs to be bled from the top. Bleed as usual, then crack the banjo bolt at the master cylinder (rag under to catch the fluid), squeeze the grip, tighten the bolt, release, correct the fluid level, repeat, repeat. It can be tedious, but it'll finally yield a firm lever. It sometimes helps to strap the lever down to the grip overnight.
post #8 of 15 Old 11-07-2013, 08:26 PM
I agree there is no significant difference on how to bleed brakes with or with out abs system. To fasten the bleeding process you can use of a bleeding tool such as this.
kartl is offline
post #9 of 15 Old 11-08-2013, 01:59 PM
Green427's Avatar
I have one of those vacuum bleeders. Works great when you don't touch the master cylinder banjo bolt or let the master cylinder go dry. I still had to bleed trapped air from the bolt after putting a new extended hose in.
1995 Honda CB750 - sold
2005 Honda Rebel -sold
1990 Honda PC800 -sold
2007 DL650 - sold
2011 DL650A - current
Green427 is offline
post #10 of 15 Old 11-08-2013, 03:09 PM
soon to find out
for the seond time dealer is trying to get the correct seals for my front calipers, and after he suceeds I will be bleeding my 2007DL650A front brakes.
