Top case Installation, remove pad? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 10-02-2011, 03:26 PM Thread Starter
mhoffm's Avatar
Do you guys remove the stock rubber pad and mount top cases with it removed? I want to attach a Pelican case, just not sure wheher to leave it on or off. It seems like pulling it off the rack, may ruin the ability to re-attach. And, maybe the pad would keep things quieter.
Thanks,
2007 Triumph Bonneville
2007 DL650 (Prev bike)
mhoffm is offline
post #2 of 7 Old 10-02-2011, 06:01 PM
not sure about others, but with my GIVI top case i left the rubber pad in place. was able to mount the GIVI mounting plate to the rear rack with the rubber pad in place. not sure about the Pelican set up ...
manleytoulin is offline
post #3 of 7 Old 10-02-2011, 08:17 PM
Yak
Yak's Avatar
it is easy to remove and reattach later. use a little dish soap to lube the rubber inserts and pull it off.
DL650A K7
Yak is offline
post #4 of 7 Old 10-02-2011, 08:52 PM
Stalky Tracker's Avatar
What Yak said; comes off easily with dish soap and a little push from the underside.
If you are installing a Givi monokey mounting plate ( E528 ), I believe you must remove the rubber pad as the mounting brackets use the same holes that hold the rubber pad. I don't know about the Givi monolocks or other brands of top cases.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 7 Old 10-02-2011, 11:02 PM
BobbyLee666's Avatar
I removed the pad before I installed my Pelican (clone) case. I used some of the U-shapped wall brackets from Home Depot to make a standoff so that I could move the case back a few inches to give some additional space on the pillion. Worked very well.
The destination is not important, only the ride there...
Current bike: 2007 HD XL1200C (soon to be back on a 05 VStrom 650)
Previous bikes: Several
BobbyLee666 is offline
post #6 of 7 Old 10-04-2011, 12:34 PM Thread Starter
mhoffm's Avatar
I went this route, and the case seems good and solid.
Thanks,
Mike
mhoffm is offline
post #7 of 7 Old 10-08-2011, 12:53 AM
A Caribou top case mount plate requires removal of the rubber pad.
on_the_edge is offline
