How to move the throttle tube? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 09-21-2011, 03:13 PM Thread Starter
pmk
pmk's Avatar
Sorry, stupid question I'm sure but I can find it using the search....
I need to move the throttle tube inward a smidgeon to install the Kaoko Throttle lock, and it doesn't seem to move after I loosen the various screws I see on the body assembly. Is it pinned?
As you can tell, I haven't really learned my way around my new Wee yet.
thanks,
pmk
pmk is offline
post #2 of 11 Old 09-21-2011, 04:19 PM
It is pinned.
post #3 of 11 Old 09-21-2011, 06:22 PM Thread Starter
pmk
pmk's Avatar
Thanks, gw, so how do I unpin it and move it 2mm?
pmk
pmk is offline
post #4 of 11 Old 09-21-2011, 06:24 PM
You would need to remove the housing and grind off the tab that fits the hole in the bar. You could also shorten the throttle tube.
post #5 of 11 Old 09-21-2011, 06:27 PM Thread Starter
pmk
pmk's Avatar
Well that doesn't sound like much fun.
...or perhaps I could insert a small spacer into the Kaoko Throttle Lock assembly to give me a tad more play.
Thanks for the info.
pmk
pmk is offline
post #6 of 11 Old 09-21-2011, 08:09 PM
LordSmoke's Avatar
I had no problem on my '06 Wee. I believe you are supposed to adjust the position of the throttle lock relative to the tube, not the other way around.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #7 of 11 Old 09-21-2011, 09:36 PM Thread Starter
pmk
pmk's Avatar
That's what I did, Lordsmoke, though the directions specifically say to "remove the alignment pin." I think they're paranoid about lawsuits.
It works great on the highway!
pmk
pmk is offline
post #8 of 11 Old 09-22-2011, 04:21 AM
LordSmoke's Avatar
Interesting. I certainly have no memory of doing any grinding. I will have to go check. I did find on a recent trip that my Kaoko didn't do so well with my new Oxford gripe. Kept slipping.
post #9 of 11 Old 09-22-2011, 08:00 AM
If it has to go in can't you just grind it shorter ?
To use my NEP I had to grind it round smooth etc
richw is offline
post #10 of 11 Old 09-22-2011, 09:14 AM
I didn't have to do anything to the throttle to install my Kaoko on my 08 Wee. I just put the Kaoko in where it needed to be to work.
coral_snake is offline
