Changing front sprocket on DL1000 k6 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-06-2011, 11:42 AM Thread Starter
Need some help changing the sprocket, this is the first time for me on the V. Have done plenty of others but the V is different. [ain't that the truth?] Anyway cover is off and I assume the little knobby nut is part of the speed sensor. Does it come off with the allen bolt? and what is the size of the sprocket nut? I thought I'd read that is 32 mm,but it's not. Is there a totourial on this job? Don't want to make a mess of this.
thanks for any help
Golden
Bub
06 V Strom
09 XR1200 Harley
09 FZ1 Yamaha
post #2 of 7 Old 09-06-2011, 12:51 PM
Remove the allen head, then you can remove the nut. I am not sure the size but 32 sounds about right. The nut is on tight and I used a impact gun on mine. I put a broom handle through the back wheel resting on the swing arm on both sides to keep the wheel from turning.
I have used a torch in the past to heat the nut a bit if no impact gun, It will loosen the thread locker. Good idea to put Locktight when putting on the new one
You will need to screw the chain adjusters all the way in to remove the chain from the sprocket. The tricky part is putting the clutch cover back on, make sure you get the spacer in correctly and tighten slowly .
Buffalo rider is offline
post #3 of 7 Old 09-06-2011, 02:41 PM Thread Starter
Thanks Buffalo
Got it, I just wasn't sure about that allen head bolt. And the sprocket nut is 32mm. Parts are off, just waiting on FedEx to bring my new sprockets and chain. The sprocket nut was tight, but not as tight as I thought it would be. Cheater bar worked fine.
thanks again
Bub
06 V Strom
09 XR1200 Harley
09 FZ1 Yamaha
post #4 of 7 Old 09-08-2011, 12:09 AM
banjobart's Avatar
I just did that job recently and somehow pinched the kickstand cut out switch wire under the clutch cover. It was easy to take the clutch cover back off and route the kickstand wire correctly.
2007 DL1000
2013 CB1100
2013 Ninja 1000
2011 GSX1250
2007 FJR1300
banjobart is offline
post #5 of 7 Old 06-01-2013, 01:20 PM
I will be doing this Tuesday. I'd like to record it and put it on youtube, but this is my first run at changing it. I want to make sure I'm stepping through it properly. Can anyone take the time to write a step by step procedure?
2012 DL1000 Adv
Heated grips, Sargent seat, 12v acc outlet, 6 circuit (Fuzeblock) add on, EB H4 light relay, Altrider crash bars & Skid plate, K&N filter, PWD Fork brace, mirror extenders, GPS shelf, Stebel Nautilus horn; Rear wheel spacer mod; Vibranators (keeps my hands awake! and yes they do work), Delkevic Exhaust, 16:43 gears;
bicdaddy is offline
post #6 of 7 Old 06-01-2013, 01:38 PM
Scott E. Bonds's Avatar
"You will need to screw the chain adjusters all the way in to remove the chain from the sprocket."
I do not see this need. I loosen the front sprocket nut first while the rear axle/wheel is still on, in place and tight. Lock rear brake or broom in the wheel trick when removing counter sprocket nut. Then I loosen and pull axle. Shove wheel forward, and chain will come right off.
Biggest trick to this repair is deciding how to deal with the clutch slave cylinder. Tie or not to tie off the clutch handle....I am a no tie guy.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #7 of 7 Old 06-01-2013, 08:53 PM
Just as an FYI for future viewers, AutoZone has 32mm sockets that you can borrow with a security deposit. Save you the cost of a 32mm socket that is a bit pricey.
sjsred323i is offline
