Loose Mirror - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-10-2011, 02:57 PM Thread Starter
Loose Mirror
My left mirror stem turns due to wind pressure when I ride. I tightened the bolts but the stem still swivels..
Any thoughts?
Thanks
albmw1100rtp is offline
post #2 of 3 Old 08-10-2011, 03:18 PM
1 Wheel Drive's Avatar
Try taking it apart and cleaning things up. It is a compression sleeve with several vertical slits in it to form fingers. When the nut is tightened it compresses the fingers around the shaft of the mirror stem. If the slits between the fingers are filled with crud or corrosion it won't grip the shaft properly.
Or you could just replace the mirrors with the much sexier Aprilia Tuono mirrors. They are dirt cheap (paid < $25 each for them at the local Aprilia dealership) and look like this:
Note that I also have mirror spacers for higher/wider mirrors 'cause I'm a big lug.
1 Wheel Drive is offline
post #3 of 3 Old 08-10-2011, 03:42 PM
randyo's Avatar
Any thoughts?
Thanks
if its still under warranty, take it back to dealer, I did, got a new mirror on the side that was drifting with wind pressure
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
