need 12v outlet help before the ride tomor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 08-05-2011, 09:49 PM Thread Starter
dieselndixie's Avatar
so, I got the relay installed. neg to ground on battery, pos to fuse then pos battery terminal. and a wire to the ignition fuse for switched power.
then I have a pos wire running from the open terminal on the relay, to the "green" wire from the 12v outlet.
the black wire from the outlet is directly run back to the negative terminal on the battery for ground.
I use my multimeter on the 12v outlet. no power while the key is off, and 12v when the key is turned on. If I switch the needles on the multimeter to the red in the center piece, and black touching the sides its -12V
do i need to just swap the wires and run green to negative terminal and black wire from outlet to pos????
nothing happens when I plug my gps in. Fuse at battery is fine.
'07 Vee - 21k miles -Maxxis Detours, skid plate, crash bars, russel day long / sargent, bags, madstad/mp screen, wilbur 640 shock
dieselndixie is offline
post #2 of 2 Old 08-05-2011, 11:21 PM Thread Starter
well, looks like user error.
the outlet has 2 wires....bright green, and black. I assumed bright green was pos. it appears to be that green is ground, black is pos. after i measured my cars 12v outlet and matched the polarity to the new 12v outlet....i figured that out.
but, my gps still didnt work.
FUSE WAS BLOWN IN GPS POWER ADAPTER
Im working now!
