Tire bead breaker from wood scraps! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-30-2011, 03:47 PM Thread Starter
honest bob's Avatar
Tire bead breaker from wood scraps, because I like to build goofy stuff.:biggrinjester: The stand under the table is actually a front wheel chock I use to hold the bike sometimes. You could use any similar leg material.
honest bob is offline
post #2 of 7 Old 06-30-2011, 09:47 PM
dtalk's Avatar
Looks like the kind of thing I'd make. See? It does pay to keep those scraps of 2x4 and plywood!
Only problem is that it occupies a lot of real estate for a seldom-used tool. I can't spare that kind of square footage, but if you can, awesome.
dtalk is offline
post #3 of 7 Old 06-30-2011, 09:55 PM
I have a similar setup for a jointer and planer. It folds up against the wall when not in use. It looks like that would be possible with a tire station too.
post #4 of 7 Old 06-30-2011, 10:16 PM
dtalk's Avatar
Oh! I just realized what you meant -- see? You are truly my brother:
http://www.flyingjoke.org/motorcycle...sc/tiedown.jpg
I credit Don Eilenberger (of the BMW "big list") for the design.
dtalk is offline
post #5 of 7 Old 07-01-2011, 12:05 AM
Shucky darn, for the trouble I go to the local tire guy. I just priced a series of tires and may go with the Anakees because of the price of a set of tires mounted and balanced.
It's just horrible what the tire makers want. $300+ semolians for new rubber. WTF?
notacop is online now
post #6 of 7 Old 07-01-2011, 09:10 AM Thread Starter
honest bob's Avatar
You got it! A big thanks to Don E. I don't leave it assembled, 6 wood screws and it is stored flat against the wall.
post #7 of 7 Old 07-01-2011, 09:14 AM Thread Starter
honest bob's Avatar
Good idea greywolf. I actually have done that with a work bench on the opposite wall. It's on door hinges and just falls flat against the wall when not required.
