DL-650 Cam Chain Guide bolt tension - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-11-2011, 03:21 AM Thread Starter
submdi's Avatar
Anyone know what the tension is for the Cam Chain Guide? (Goes over the top of the Cam Chain, held down by 3 bolts)
The manual simply says "Install the cam chain guide"
No torque is given.
They were tight to break.
'08 DL650 ABS
Givi Crash Bars, MadStad, Givi 21L Panniers & 52L Top Box, submdi Stone Guard, submdi Rad Guard, Starcom1 Advance, GME GR100 FM Radio, Zumo on submdi mount, Oxford HotGrips, AirHawk Seat Pad, DR650 Pegs, submdi Chain Oiler
submdi is offline
post #2 of 6 Old 05-11-2011, 03:41 AM
No, but it'll be generic.
If you can't find it elsewhere measure the bolt diameter and look up steel in aluminium on the net.
Go a little on the low side since it'll be well lubed - the amount to lower the torque should be there somewhere as well.
The other option is to use a low strength threadlocker to ensure they won't back out.
Pete
PeteW is offline
post #3 of 6 Old 05-11-2011, 07:29 AM
Scarlett Harlot's Avatar
Your answer may be in Greywolf's list in this thread.
https://www.stromtrooper.com/dl650-sp...lue-chart.html
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups.Ē ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #4 of 6 Old 05-11-2011, 08:21 AM
honest bob's Avatar
It's also in the manual where they have generic torque values. Pg 9-43. If I remember correctly, they are 5mm, so 2ftlb./24inlb. About what a screw driver would apply?
honest bob is offline
post #5 of 6 Old 05-11-2011, 09:53 AM
I misread the part. IIRC, the bolts are 6mm. That would mean 7lb-ft dry or 5.6lb-ft oily.
post #6 of 6 Old 05-11-2011, 08:54 PM
Nova Scotia Strommer's Avatar
When I did the first valve adjustment a few weeks ago I remember those bolts "cracking" loose and they appeared to have the residue of loctite on them so I used some blue loctite when I replaced them.I figured it couldn't hurt as I sure wouldn't want any of them to come loose in there.
09 DL650 ABS ORANGE "Form over function at a superior price"
09 DR650 "Hooliganizer"
03 TW200 "No Roads....No Problem"
02 TW200 "Redneck Edition"
Nova Scotia Strommer is offline
