Kick stand shorter??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-24-2011, 03:44 PM Thread Starter
Due to my 31" inseam, I had to lower my Vee 3/4". Now it seems to stand up very straight and when I'm a slight incline it wants to fall over.
Seems like cutting 3/4" off my kick stand solve my problem. Has anyone else done / tried this?
Thanks, deOldfart
sweetcreek is offline
post #2 of 9 Old 04-24-2011, 07:45 PM
Nova Scotia Strommer's Avatar
This may be an option to shortening your kickstand and is easily reversed.
https://www.stromtrooper.com/dl650-sp...tml#post675944
09 DL650 ABS ORANGE "Form over function at a superior price"
09 DR650 "Hooliganizer"
03 TW200 "No Roads....No Problem"
02 TW200 "Redneck Edition"
Nova Scotia Strommer is offline
post #3 of 9 Old 04-24-2011, 08:15 PM
I found a used side stand, chopped it, and kept the old one just in case I ever want to put it back to stock.
Merlin is offline
post #4 of 9 Old 04-24-2011, 08:34 PM
Grind the stop works well & easy to do
Run with the big dogs or stay on the porch
STOC 1905
IBA 28154
2011 White Wee under construction
05 Wee @ 50 K ( Gone @ 56 K Loved that bike)
02 1800 Wing @ 83K
Home just outside of NYC & THE YANKEES RULE
ST114ME is offline
post #5 of 9 Old 04-24-2011, 11:07 PM
I have a Vee with a chopped side stand from the PO.
I'd be willing to swap it with your stock length, since I've been looking for one for a while.
Let me know!
Brooklyn, NY
2006 VStrom 1000 "Felaróf"
1985 VF1000F
1980 GS850G
CrazyGeorge is offline
post #6 of 9 Old 04-25-2011, 10:58 AM
I lowered my wifes wee 3/4" so I can answer this one. I had a machine shop cut 1" off the stand and insert a rod inside for strength and weld. cost me 20.00. 3/4" cut off will not be enough. the 1" was about right.
icnxpln is offline
post #7 of 9 Old 02-01-2012, 04:11 PM
randyo's Avatar
at stock height, my Vee leaned waaay more than it needed too, when I lowered it, it was about right without touching the side stand
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #8 of 9 Old 02-01-2012, 08:50 PM
cut an 1 1/2 " off , and it worked fine.
2011 DL-650
2005 H-D
kd4gru is offline
post #9 of 9 Old 02-01-2012, 09:39 PM
kiwi_outdoors's Avatar
grinding the shoulder (stop)
thats what I did - and I need to to a bit more of it
kiwi_outdoors is offline
Closed Thread
