Rear tire change tutorial with pics - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 16 Old 03-26-2011, 09:15 PM Thread Starter
rcacs's Avatar
This is my first go-around using PhotoBucket, so forgive any errors you might find.....
I just changed out my rear skin and figured, what the heck, I will try doing a tutorial. Hopefully some find it helpful.
This is intended for those that have at least minimal mechanical skills, but perhaps have been leary about changing their own tires. Safety precautions should be taken such as safety glass's and mechanics gloves. An extra set of hands can be of benefit as well.
I have been changing my own tires forever, and I dont worry about nicks in the wheel finish. If you are worried about nicks, scratches, etc it might be in your best interest to leave this to the pro's.
Anyhew, here it is:
Pictures by rcacs - Photobucket
Hopefully it is of some use to others...
Cheers
motofshr likes this.
rcacs is offline
post #2 of 16 Old 03-27-2011, 01:21 AM
Austin44's Avatar
Wow! That is a big clamp.
I never thought to break the bead BEFORE removing the wheel. Way better
idea.
Thanks
Austin
Austin44 is offline
post #3 of 16 Old 03-28-2011, 10:34 AM Thread Starter
rcacs's Avatar
I found that makes things much easier as well...
cheers
rcacs is offline
post #4 of 16 Old 03-28-2011, 11:34 AM
amk
I changed my 1st one a month ago. Easy peasy.
Anyway a couple of questions and an advice, for which you need a text to be tutorial. Like photo #12, I am doing so and so.
Questions, what is the wooden wedge for? The one is in the tire beside an iron?
Why breaking the bead like you did gives advantages, cannot see them.
For breaking beads clamps rule, they are in every hardware store, much cheaper than breakers, can be used for something else, work equally good.
amk is offline
post #5 of 16 Old 03-28-2011, 02:04 PM Thread Starter
rcacs's Avatar
As I stated, this was my first go with PhotoBucket. However, if you click on the first picture, it will enlarge and then you will see the text. Just click the "next" for the rest of the pics.
The "wedge" I think you are referring to is actually a piece of cardboard made into a flat funnel for pouring in the Dyna Beads.
If you have any questions after seeing my text, feel free to comment.
Cheers!
rcacs is offline
post #6 of 16 Old 03-28-2011, 02:48 PM
Good job...............!!!!!!!
Thanks for all your hard (internet) work.........I picked up a few new tips.
www.easternvstromrally.com
mark444 is offline
post #7 of 16 Old 03-28-2011, 04:38 PM
amk
Cheers!
Yes, I have not seen the text, now I do, thank you.
amk is offline
post #8 of 16 Old 04-30-2011, 03:26 PM
Welfare Funder
nice job.
2K7 Wee Strom - MadStad, Givi E52, AdMoreLighting LEDS, Power Outlet, Joe Rocket Tank Bag, Cali-Sci Windscreen (Med), Lowering Links, Center Stand, Richland Fork brace
motox-dan is offline
post #9 of 16 Old 05-11-2011, 05:44 PM
Much better than a long 2x4 wedged under the car to break the bead. Very good pictures.
GBranson is offline
post #10 of 16 Old 08-04-2013, 04:57 AM
Thanks, wish I've read more carefully. I had big problems getting the final bit on and only after advice from a guy I had the rim in the middle of the wheel on the opposite side of where the final bit was, and then I managed. But I made some ugly marks on the wheel as well as made a crack in the rubber when I was trying. Hopefully, I did not destroy the tyre.
johanbackman is offline
