How to install a battery??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 02-16-2011, 08:36 PM Thread Starter
Dread7's Avatar
I have several electrical leads on top of my battery. I took it out to charge it but when I go to re-install it the nut drops to the bottom and then I can't easily re-connect. For anyone else with that problem I just looked around for some nice plastic wire ties and it made it tons easier to put the battery posts back on the bike. Make sure you have smooth side up and don't completely tighten the connection down to make the wire ties easy to remove.
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is online now
post #2 of 9 Old 02-16-2011, 11:21 PM
dtalk's Avatar
I just stuffed a bit of folded cardboard under each nut to raise it a little. It's easily crushed by the bolt if it extends down that far.
dtalk is offline
post #3 of 9 Old 02-16-2011, 11:23 PM
dtalk's Avatar
p.s. The unfused crimp or tap connection on the positive side would make me very uncomfortable. 10 or 12ga straight to a fuse first, then any other connections downstream.
dtalk is offline
post #4 of 9 Old 02-16-2011, 11:31 PM Thread Starter
Dread7's Avatar
It actually tucks in beside the battery attaching that tiny red lead below it in the picture. That run is fused and switched, but thanks for noticing
post #5 of 9 Old 02-17-2011, 01:10 AM
donstrom6's Avatar
clovett...good tip
I just ran into this situation a few weeks ago when installing the MOSFET r/r. Too many lugs on the terminals and the screw wouldn't catch the nut threads. Wound up using a pick tool to maneuver the nut in place.
Your method is much simpler! Next time I pop off the terminals I'll make sure to shim it as shown.
DonStrom6 - PHL
Comfortably numb
DL1000K5 - Black
DL650K8 - Yellow (Sold)
donstrom6 is offline
post #6 of 9 Old 02-17-2011, 11:16 AM
Use longer screws.
post #7 of 9 Old 02-17-2011, 12:05 PM
zzzzip's Avatar
I get rid of the clutter by bending a small zip tie in a "V" and sticking it under the nut, then cutting off the excess. It acts like a spring to hold the nut in position to catch the bolt.
zzzzip is offline
post #8 of 9 Old 02-17-2011, 05:17 PM Thread Starter
Dread7's Avatar
Originally Posted by PTRider View Post
Use longer screws.
That might be a problem. When you tighten down the screws you can't remove the wire ties as the bottom of the screw connects with the wire tie and presses it against the battery. I believe a longer screw might get you a nice hole in your battery.
post #9 of 9 Old 02-17-2011, 05:29 PM
jokermtb's Avatar
I've used bits of old bicycle innertube as a spacer under each battery terminal nutt. Just kinda stays in place forever!
jokermtb is offline
