How to raise your V-Strom motorcycle with a floor jack. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 01-08-2010, 12:20 AM Thread Starter
MikeWee's Avatar
Cool How to raise your V-Strom motorcycle with a floor jack.
It's time to change the tires on my wee. I got about 9,200 miles on the old Battle Wings.
I raised the rear of the bike with a rear end lifter stand thingy. I then came up with a way to raise the front end by using a floor jack. The rear is lifted to help stabalize the bike.
What I did was make a simple u-shaped wood assembly that is put together with some long wood screws. The idea is quite simple and works pretty good.
Basically, the lift works by inserting a 3/8" bolt that is 10- inches long through the slot that goes all the way through the bottom of the engine. A couple inches of the bolt then sticks out of each side of the engine. [I think the hole is a slot to attach a center stand to lift the bike.] There is a notch on each top side of the wooden u-shaped assembly, which is where the ends of bolt rest upon. I raise the floor jack up until the bolt ends rest on the block. The jack is then raised further until reaching the desired height.
The pictures should be self explanatory.
[IMG]]http://i47.tinypic.com/34h8gwm.jpg[/IMG]
MikeWee is offline
post #2 of 12 Old 01-08-2010, 07:34 AM
Rjsurfer
Bravo
Nice and simple, usually I dug up some old pieces of 2x4 and fit them between the engine and a HF motorcycle stand. Never thought to use a floor jack.
Ron W.
07 Wee
07 DRZ400 SM (wifeys)
16 T Sprocket
Short screen & Washers
Replaced 'P" shooter
35W halogen rear signals
RT Gold Valves
Sonic Springs
rjsurfer is offline
post #3 of 12 Old 01-08-2010, 04:15 PM
honest bob's Avatar
Looks like it could be a little unstable (fall forward or to the right) but my real concern is the weight of the bolt ends (3/8" wide) bearing down on and splitting the two (or worse one) upright pieces of wood. It would be way stronger if the wood uprights were ripped with the grain to about 2 1/2" wide & then cross cut to 5 1/2" and then screwed/glued to the cross piece. This way the bolts are trying to crush the wood instead of split it.
Just my 2$ worth.
honest bob is offline
post #4 of 12 Old 01-08-2010, 05:34 PM
kenneth_moore's Avatar
The Suzuki service manual says to do it this way, using a Pit Bull type lift to stabilize the back. I used a floor jack with the cupped receiver that came with it. I was so worried about stability I asked my riding pal to come by and hold it while I tested it out. It was very stable, nary a wiggle. The 2X4 jig would only make it more stable.
Good solution!
Go hakafugu yourself.
kenneth_moore is offline
post #5 of 12 Old 01-08-2010, 11:23 PM Thread Starter
MikeWee's Avatar
You are right. It wood be better to cut the would in the other direction. I may take it a step further and build a steel jig instead.
Thanks.
MikeWee is offline
post #6 of 12 Old 01-09-2010, 02:14 AM
Dorzok's Avatar
Just my 2$ worth.
ripped, grain, cross cut?? motorcycle forum here... Norm
Somtimes it sucks not being in the loop. HUH??[FONT="Comic Sans MS"][SIZE="2"][COLOR="Olive"][/COLOR][/SIZE][/FONT]
Dorzok is offline
post #7 of 12 Old 01-09-2010, 11:28 AM
What Kinda Bike Is That?
Black Lab's Avatar
Or.....
......skidplate, block of wood, floorjack.
Instead of recutting the wood, (there is a high risk of the blocks splitting with the "end grain" of the wooden blocks being in contact with the bolt. Particularly as the wooden blocks dry out over time.), purchase a pipe adaptor/nipple and cut it in half. Use one half of each as a "half-bushing" down in the detents where the body of the bolt lays across the wooden block. Doing this will probably disperse the pressure enough to keep the blocks from splitting.
EDIT: This morning, this is where my bike is at right now. The rear is hung from the garage ceiling by a come-a-long and also supported by some blocking underneath the bike's frame, (doing swingarm bearing work), and the front is held up and stabilized by ratcheting tie-down straps from the crashbars to the garage ceiling joists. The front is also stabilized with a jackstand "hooked" into my crashbars, (rebuilding the speedo sensor and changing a front tire.).
Black Lab is offline
post #8 of 12 Old 01-09-2010, 12:04 PM
Chewy's Avatar
Originally Posted by Black Lab View Post
Or.....
MikeWee,
If you're gonna keep that wooden setup.....I'd suggest re-doing the small notched vertical blocks and orient the grain of the wood so that it runs on a horizontal plane instead of vertical....then it won't split.
Better safe than sorry....or a rashed V-Strom.
Chewy is offline
post #9 of 12 Old 01-09-2010, 02:18 PM
maydaymike's Avatar
I just use the centerstand, and then use a floor jack with a block of 2x4 between the jack and the bottom of the engine case to lift the front wheel. Most of the weight is on the centerstand anyway. It really doesn't put much stress on the engine case.
2007 DL650 52k RIP 8/31/10 :sad1:
1983 Mercedes-Benz 300SD 273k
1960 Ford f250 62K
Silver Strom Club #37 :mrgreen:
The thing is Bob, it's not that I'm lazy, it's that I just don't care.
maydaymike is offline
post #10 of 12 Old 01-12-2010, 07:56 PM
honest bob's Avatar
Originally Posted by Chewy View Post
MikeWee,
Thanks for that confirmation
Tags
change , floor , jack , lift , tires
