Healtech OBD tool owners chat - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 3 Old 08-02-2019, 11:35 AM Thread Starter
Hello to All,
If you own a Healtech OBD tool please reply to this inquiry.
I would like to establish relationships for sharing and learning about the tool
Thanks,
ob
vegashotwheeler likes this.
post #2 of 3 Old 09-24-2019, 08:47 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
No experience with the Healtech, just a question about it.
Does it do more than using the onboard diagnostic?
I have the dealer switch permanently installed on both my bikes, bike starts acting up I just lift seat and click the switch and then look up code on my iPhone.
Not trying too redirect your post, just wondering if you can do the same with a jumper in the diagnostic port?
Mike
Sent from my iPad using Tapatalk Pro
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #3 of 3 Old 11-15-2019, 03:04 AM
Grimmer's Avatar
I have the Healtech OBD-S01 and have used it several times.
Yes the Healtech does more than just read the error codes. It monitors and records many of the data streams from the ECU and ABS module. Most importantly it will perform some of the maintenance procedures such as the ISC lockout and the ISC learned position reset which are required for the throttle body sync procedure on the 2014+ DL1000 (among others). It can also force actuate things like the exhaust valve, secondary throttle valves, EVAP purge, cooling fan relay, etc. However, the one thing it doesn't currently do that I really wish it would is actuate the ABS pump.
I've also heard rumors that Healtech is working on refreshing their product line. No idea what that means or when any new products will be available...
For me the local dealerships were quoting pretty much the same price to do the throttle body sync as it cost to buy the Healtech tool and do it myself.
Grimmer is offline
