Power Probe III Inquiry - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-15-2019, 04:02 PM Thread Starter
BigSky's Avatar
As I try to expand my capabilities in the world of 12V electricity/electronics I keep seeing references to the Power Probe. I've watched a couple of youtube videos and it intrigues me and looks like it may be quite useful, even for someone like me who is generally paralyzed from the neck up when it comes to electricity.
For those of you who have and use these, what are your thoughts? Are they worthwhile for the average Joe working on his bike/boat/truck in his garage? If so, please provide us with some of the most useful functions it provides. Thanks in advance.
BigSky is offline
post #2 of 4 Old 05-19-2019, 02:59 AM
RoadWarrior1978's Avatar
Assuming a Power Probe is the same thing over here in the UK I would say they can be invaluable,
Being able to test for earth and power, then with the touch of a button create an ad-hoc earth or power feed all in one device saves so much time.
It's not yellow, it's "YELLOW!!!!"
RoadWarrior1978 is offline
post #3 of 4 Old 05-20-2019, 11:53 AM
It's nice but a regular multi-meter and a sewing pin can get the same results.
Used to do dat all the time when I worked and when doing work on my own toys.
The sewing pin makes a pretty small hole that doesn't cause problems.
It helps to have leads that have alligator clips on them
post #4 of 4 Old 05-20-2019, 04:28 PM
dravnx's Avatar
You can do any type of motorcycle electrical troubleshooting you'll ever need to do with a cheap multimeter and it's leads, a few jumper leads with alligator clips on either end and couple of stout sewing needles. Don't spend more then $30.00 for the multimeter.
https://www.homedepot.com/p/Klein-To...M300/206517192
https://www.amazon.com/Pieces-Alliga...a-649001696791
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
Power Commander 5 cruising MPG issue, And tuning questions plus my experiences so far Wrathchild DL1000A - 2014-2016 42 04-10-2017 08:05 PM
Weekend project - aux power Brojon DL650A - 2012-2016 1 05-02-2016 03:08 PM
Power Outlet Problem Jim Judd DL1000A - 2014-2016 8 03-22-2016 12:12 AM
Intelligent Power Management for V-Stroms, features Trepidator V-Strom Modifications and Performance 0 02-26-2016 03:17 AM
Power Commander or re-gear? Power commander 3 or 5? Red5 DL1000 from 2002-2012 12 12-30-2013 07:53 PM
