2012 Vee Tank Removal Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 04-23-2019, 07:27 AM Thread Starter
Big Boy's Avatar
Newbie Here!!! This is my 1st attempt at removing the gas tank.
Background: I need to remove the gas tank to gain access to the speedometer coupling. My intention is to install the SpeedoDRD speed correction device as well as replace the air filter.
I have a service manual that indicates the plastics need to be removed. Excerpt shown below.
I've also searched for tips/tricks on tank removal on this site. I found a reference to the official tank removal thread on the international site. However, I couldn't access the info.
I also searched YouTube for any helpful videos. I found a video showing the removal of the tank WITHOUT removing the plastic as shown in the service manual.
My Question to The Collective
- Will this work for my 2012 Vee???
- Does anyone have any advice?
Any and all help is appreciated!
Thanks in Advance
Big Boy
W. C. Fields
Big Boy is offline
post #2 of 11 Old 04-23-2019, 10:04 AM
blaustrom's Avatar
Take the side cowlings off. Im not sure about the VEE but my WEE had at least one bolt going into the tank. No biggy, just do it. In future it will then be just 5 minutes. Just remember which bolts go where and keep them in a little jar or plastic pot to be sure non get lost.
Then undo the rear bolt, lift up the rear of the tank and disconnect the fuel pump connector and the fuel line and the vent and overflow hoses. Then support the rear with the little bracket set on end. Remove the front bolt (mine was 10mm socket). Done, lift it off.
Best if the tank is kind of empty since its not so heavy with less fuel in it. Make sure you have a safe and sturdy place where to rest it (how do I know??).
Whilst you have good access check all the electrical connectors to make sure they are clean. not oxidized and protected from the elements as fas as possible. It's recommended to reassemble with contact protection sprays or dielectric grease.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 11 Old 04-23-2019, 11:10 AM
The 12-16 650's must have the tank plastics taken off and tank lifted, it isn't the same design as what you linked. It's easy once you do it a few times, I can lift my tank quicker on my 15 than I could on my past 1000's. You can take the plastics off and still be able to have the tank on for access below, the piece that bolts down the tank near the seat is also a lift/wedge.
post #4 of 11 Old 04-23-2019, 11:54 AM
blaustrom's Avatar
He has a 2012 VEE
Blau2 2014 DL1000A
post #5 of 11 Old 04-23-2019, 02:42 PM Thread Starter
Big Boy's Avatar
Amazingly, the 'easy' tank removal procedure from Post#1 worked great!!! I was able to install the the speedo correction device and change out the NASTY air filter. Looks like the PO had not performed that maint. in a very long time!!!
Damn that tank is HUGE!!!
W. C. Fields
Big Boy is offline
post #6 of 11 Old 04-23-2019, 03:10 PM
portabill's Avatar
My universal tip is to empty the tank first!
Moderator ChristianADVRider.com
2006 WeeStrom
2007 KTM 450 EXC
portabill is offline
post #7 of 11 Old 04-23-2019, 03:31 PM
Webfors's Avatar
I know what the manual says is the interval for the air filter replacement, but what does the collective recommend?
Two wheelz for realz!
Webfors is offline
post #8 of 11 Old 04-23-2019, 05:46 PM
larolco's Avatar
I have a K&N in mine and clean it about once a year and it usually needs it.
But really, it depends on what kind of riding you're doing. Dusty dirt rides shorten the interval dramatically.
But, if you put on a lot of miles in the rain, the weather does your filtering for you.
If it's just leaves and bugs, you can often just tap the filter clean and reinstall as an interim measure.
Webfors likes this.
DRZ400SK17
larolco is offline
post #9 of 11 Old 04-23-2019, 06:57 PM
Hard miles's Avatar
I do the filter once a year prior to winter storage. In general I replace it every 2 years but blow it out every odd year. I could probably go to a 3 year cycle. Mileage varies between 22,000 to 29,000 km /year.
Webfors likes this.
Hard miles is offline
post #10 of 11 Old 04-23-2019, 11:48 PM
Originally Posted by blaustrom View Post
He has a 2012 VEE
Well damn, reading comprehension got best of me again, sometimes I also forget there is a 2012 1000 as few here seem to have them.
Glad the OP got it figured out and resolved.....
2012 dl650a abs top brake line extension question sjsmith8688 DL650A - 2012-2016 9 04-09-2015 10:12 PM
Fuel tank hoses on Glee Bemidjipaul DL650A - 2012-2016 4 01-31-2015 12:16 PM
basic question about low seat for 2012 DL650A Jess Gropen Maintenance, Tech and Products. 3 05-03-2014 11:13 PM
Has anyone tried the the Nelson Rigg CL-1035 Tank Bag on a 2012 650? I922sParkCir DL650A - 2012-2016 12 10-28-2013 12:21 PM
Anybody bought the 2012 Suzuki Tank Bag cycleman DL650A - 2012-2016 11 10-24-2013 06:20 PM
