LED Indicators/Running Lights How To - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 3 Post By Brockie
  • 2 Post By thirdofthree
post #1 of 3 Old 04-23-2019, 06:32 AM Thread Starter
Brockie's Avatar
I have changed my DL650 indicators to LED indicators/running lights. They cost me $3.13 a pair, plus $4.48 freight.
They are available as amber/white, amber/red, amber/blue, and amber/amber (which is probably illegal in most places). https://www.aliexpress.com/item/Pair...862333482.html
I bought an amber/red pair for the rear and connected the red LED to my brake light.
Also a pair of amber/white for the front. They come with no instructions so touch them across your battery to see which wire is which. I have forgotten the wiring colours but the earth is either green or black.
One issue is that the reduced draw will cause the indicators to hyperflash. This is a safety protection to tell the rider that at least one of his indicator bulbs is not working. The easiest way by far to cure this is by buying this LED replacement flasher relay. It is a direct pull-out, plug-in replacement for the original OEM Suzuki relay. It's under the seat just in front of the battery. https://www.ebay.com/itm/Flasher-Rel...QAAOSw44BYeIAX
Byronw, thirdofthree and NVDucati like this.
Brockie is online now
post #2 of 3 Old 04-23-2019, 10:19 AM
I converted my front turn signals to running lights / turn signals with the Blinker Genie. But I haven't found a good solution for the rear turn signals that incorporates amber signals with red running (and ideally brake) lights.
How bright are the running light and turn signal portions? I'd love to see some pictures or video of them in both daylight and night.
Byronw and SuperG like this.
thirdofthree is offline
post #3 of 3 Old 04-23-2019, 12:32 PM
Webfors's Avatar
Video!!
I converted to cheap LED bulbs last year, and the result is quite good. But those looks slick.
Two wheelz for realz!
Webfors is offline
Dimming Aux LED Fog / Spot Lights - 3 options; others? thirdofthree Maintenance, Tech and Products. 0 04-27-2018 12:07 PM
LED lights on my Vee Crew_Dawg_Dave V-Strom Modifications and Performance 0 05-04-2015 02:14 PM
conspicuity lighting - Skene design, modulator and handguard lights Alan Lloys DL650 and DL650A - 2004 to 2011 14 07-15-2014 03:03 PM
LED driving Lights zed88 Techy World! GPS, Electronics, etc 8 07-13-2012 12:40 AM
My Glenda and Krista Clearwater Lights mbrinitzer Techy World! GPS, Electronics, etc 6 06-12-2010 03:01 AM
