Removing Clutch Cable - help! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By David Waldo
  • 2 Post By blaustrom
  • 1 Post By Brockie
post #1 of 6 Old 04-15-2019, 04:28 PM Thread Starter
Hello everyone. I'm in the process of replacing my stator and according to the Haynes manual step one is removing the clutch cable. According to the Haynes manual there is a small clip holding the cable in place and that one should be able to slip a small flat head screwdriver in and bend down the clip. For the life of me I cannot get it to bend down. Is there a trick that I need to know about?
Thanks!
Mursinary is offline
post #2 of 6 Old 04-15-2019, 05:40 PM
David Waldo's Avatar
I am not sure but maybe a circlip on the backside of that pin where it hooks to the linkage?
Mursinary likes this.
2011 DL650A, 2008 C50T
David Waldo is online now
post #3 of 6 Old 04-15-2019, 10:43 PM
eff
eff's Avatar
Should come right off. I had mine apart and cleaned it when I changed my front sprocket.
You need enough slack to release it.
Sent from my Pixel using Tapatalk
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #4 of 6 Old 04-15-2019, 11:36 PM
blaustrom's Avatar
1+
Give it a lot of slack or better yet unhook the cable at the lever. Then it will come right out.
tucsonray and Mursinary like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 6 Old 04-16-2019, 12:39 AM
Brockie's Avatar
The reason why you need to remove the clutch cable is that the bottom clutch cable adjuster(A) is mounted to an extension of the generator cover(B).
To remove:
  • Loosen the top clutch adjuster at the lever to give maximum cable play.
  • Push the nipple in your picture backward/downwards. The top part of the nipple is slimmer and you can then side it sideways and off of the actuator arm.
  • Loosen the locknut of the bottom clutch cable adjuster.
  • Unscrew the bottom clutch cable adjuster out of the generator cover so that you can then remove that cover for access to the stator.
When you install the new stator only torque the bolts lightly to 8lb/ft, and the two CKP sensor set bolts to 4.7 lb/ft.
Brockie is offline
post #6 of 6 Old 04-16-2019, 11:39 PM Thread Starter
Thanks for the assistance everyone, I undid the cable from the lever and managed to get it off. I will say that changing out the stator and R/R is a much more involved job than I thought it was going to be! Here's to hoping I can get everything back together correctly!
Clutch cable snapped! DMNordin General V-Strom Discussion 16 12-23-2017 08:59 AM
Adjusting clutch cable with OEM handguards SpaceKnight DL650A - 2012-2016 3 08-09-2014 06:55 AM
DL1000 clutch won't release Stobie V-Strom Service and Maintenance Questions and Discussions 14 12-28-2012 04:01 AM
clutch cable barrel won't come out gme DL650 and DL650A - 2004 to 2011 1 11-20-2010 04:32 PM
Clutch cable replacement advice needed DTP V-Strom Service and Maintenance Questions and Discussions 9 05-25-2009 11:31 AM
