2015 V-Strom 650 speedo sensor connector - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 03-10-2019, 10:35 PM Thread Starter
Hi, having trouble with the speedo on my 2015 vStorm LAMS, hence decided to put in a speedo healer. However following the instruction manual that comes with the kit, i am unable to find the speedo sensor connector (which is supposed to be a 3 wire white connector) on the vstorm.
Anyone got any ideas where this connector is lurking? Photos would be ideal.
vkerai is offline
post #2 of 2 Old 03-10-2019, 11:27 PM
jgendr's Avatar
I installed one on my 14 650. If you look just above the front sprocket you'll see the plug your looking for. It's behind the frame and a real bear if you got fat hands. Also when you set it up via the instructions, if you cant get it into setting the offset the unit may be in factory mode. I had to send mine back for an exchange. can't remember what it displayed but it wasn't what the instructions said it would be. Love the Speedo healer, Hollar if you need help
Here is what I got "I got my SpeedoHealer Yesterday in the mail. I ordered it from Amazon. The hardest part of the install on my 14 Weestrom was finding the speed sensor plug. (FYI for all you 14 and newer weestrom guys it above the clutch arm on the engine behind the frame.) I followed the directions and plugged it in. powered it up and all it said was "F2" and couldn't get it in to test mode. So just like you I Flaked out and got a little pissed. I shot off a message on the Healtech website and was responded back in less than 12hrs. "F2" means it was left in Factory test mode and needs to be sent back. I also called Todd at Blue Monkey (Healtech's US distributor) And had no issues getting a replacement sent out.""
JG
2014 DL650 VStorm
jgendr is offline
