Anyone bought their wheel bearings from a bearing supplier? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 51 Old 12-18-2018, 10:54 AM Thread Starter
RCinNC's Avatar
I'm thinking of replacing the wheel bearings in my Super Tenere this spring when I do my next tire change. I've heard that some guys have sourced their bearings directly from a bearing supplier, rather than the OEM parts (for the obvious reason od the potential cost savings of buying bearings without the OEM markup).
Has anyone ever done this? Can you recommend a particular online bearing supply business that you dealt with that carries the more reputable brands like Koyo or NTN? I'm not interested in things like All Balls bearings.
RCinNC is online now
post #2 of 51 Old 12-18-2018, 11:13 AM
I have, but it isn't all that easy. We have place in Houston that has bearings, and I mean LOTS of them in stock. Houston Bearing & Supply. Used to have a really good online chart. There are places like this in most metropolitan areas.
But don't go there and ask for bearings for your Super Tenere! They operate by OD/ID/width and then there is a LOT of choices in the range you need. Such as load/speed factors, sealed or not, etc.
If you have the information on size from someone that has already been through it, that is wonderful. You will probably be able to buy better bearings than came in your bike. Don't worry too much about brand. They can answer questions about quality if you ask them.
If you have no idea what sizes are, it may not be worth the time. You can take the bearings to the supplier, they are good at measuring them. But that is some time and work involved. Ordering replacements from a dealer might not be all that bad if time is considered.
realshelby is offline
post #3 of 51 Old 12-18-2018, 11:27 AM Thread Starter
RCinNC's Avatar
Thanks, Realshelby. I have what I think are the actual sizes (example: 22x50x14), and also various manufacturers' sizes like 60/22 2RS. Trouble is that it came from the 'net, and I'm not sure how accurate it is. I didn't know about the load ratings; I figured a bearing with the right measurement and manufacturers' number would be correct, but didn't know that there might be differences in load ratings within that category.
post #4 of 51 Old 12-18-2018, 11:45 AM
RC, look up "Bearing Headquarters" and check if there is one there is one in your area.
The bearings in your bike will have international numbers on them, and BH can use these numbers for replacement.
2 summers ago I had a rider friend come visit me in St Louis from New York. I let him use my garage for maintenance while he was here, and he had me check his bike out.
His front wheel bearings were loose. I took off the front wheel and removed a front wheel bearing from the rim hub. 1st call was to a CarQuest auto parts store I deal with as a commercial account. I gave them the bearing numbers, they had 2 in stock and the rest is history.
Many of these wheel beaings come oem with one side sealed the other side open with the bearing seal facing out. When I replace wheel bearings I locate double-sealed bearings. Ive used NTN, Bower BCA, New Departure Hyatt, Timken, and FAG bearings depending on who has what.
MAZ4ME is offline
post #5 of 51 Old 12-18-2018, 06:08 PM
STCorndog's Avatar
I have a set of new OEM S10 bearings and seals my buddy at the dealer gave me when I "thought" my S10 needed wheel bearings. They are double sealed and I could give you the bearing numbers to cross reference if it helps. Korean made if I remember correctly. For my Strom I bought NTN bearings locally that were double sealed and seemed to hold up well.
But, I have a question that has been checked on another bike and sort of double asked on the YST forum. On my old Strom, if you picked up a wheel by the inner bearing races and spun the wheel, the bearings would turn very smoothly. When I did this with my S10 wheel, the bearings felt tight and the inner races would spin on my fingers instead of staying stationary. I found out by asking around at YST, that the S10 bearings feel tight until the inner races are pushed against the collar (if this makes sense). If I use my thumbs and push inward on both bearing inner races to keep them from rotating and roll the wheel on a floor, they feel smooth (this is not easy to do by the way). I am not sure if this is what Yamaha intended or if the collar may be too long or the wheel machined wrong where the bearing OD sits. Another S10 wheel seemed the same as mine.
I went so far as pulling my calipers and mounting the wheel with the original bearings, spun the wheel and I think they are good. It makes it hard for me to judge the bearing wear though. I discovered this at 18,000 miles and it seems the same at 24,000 miles. I tossed the new bearings in the spare parts box and am running the old ones for now.
Your thoughts RCnNC?
STCorndog is offline
post #6 of 51 Old 12-18-2018, 08:24 PM Thread Starter
RCinNC's Avatar
I'll be honest, I don't think I've ever tried to turn the bearings with my fingers. When I check the bearings, I just pull the wheel from side to side to see if there's any play in it. I have taken the wheels off to change the tires, and when I do, I balance the wheels in one of those Marc Parnes balancers. Those have cones that fit inside the bearings to support the tire while it's being balanced. The balancer looks like this:
The whole axle, cones, and wheel rotate as a unit when the wheel is spinning; the unit sits on those bearings at each end of the axle, and it rotates on those bearings. The cones don't exert any inward pressure on the bearings the way a tightened axle on the bike would. My guess is that the inner races aren't moving while the wheel is being balanced, or else the axle of the balancer wouldn't be rotating on those bearings. So I'd guess if I tried to spin the inner races by hand, I'd probably experience the same tightness you did. If they weren't tight, then the wheel would rotate around the wheel bearings when it was on the stand, and the whole unit wouldn't be rotating on the axle of the balancing unit. Hopefully, that makes sense.....
If you have that set of OEM bearings, it would be awesome if you could read the numbers off them (or even take photos of them), so I can see if the numbers match up with what's available from bearing supply houses. There should be three different sizes of bearings in the set. The front bearings and the rear wheel non-drive side should measure 22x44x12. The rear wheel drive side should measure 22x50x14, and the bearing in the clutch hub should measure 25x47x12. I believe the front bearings and the rear wheel non drive side bearing should have a number something like 60/22 2RS, the rear wheel drive side should be something like 62/22 2RS, and the clutch hub should be something like 6005RD or 6005 2RS.
Thanks, I really appreciate the help!
STCorndog likes this.
post #7 of 51 Old 12-18-2018, 09:02 PM
Wow! Another Marc Parnes balancer owner! I stopped using mine when I bought a No-Mar Balancer Stand.
MAZ4ME is offline
post #8 of 51 Old 12-18-2018, 09:26 PM
STCorndog's Avatar
I only have the fronts. My buddy ordered them from Yamaha, he is the Service Manager. They were covered by my YES warranty but I chose to wait for now to install. I am listing part numbers so you can verify they were ordered correctly.
Seals PN 93106-28043 (M180124A).
Bearing PN 93306-07208 (K180306A). They are stamped KBC 6004DK on seal area. On outer race smaller numbers F845006. Korea.
P.S. - Getting old crappy eyes disclaimer 6004DK could be 80040K. Pretty sure I have it correct though and they are double sealed. If you cross them to Japanese bearings I would like those numbers please.
post #9 of 51 Old 12-18-2018, 09:32 PM
STCorndog's Avatar
RCinNC - I have an extensive maintenance/parts list for the S10 from YST, but as luck would have it the bearings were not listed. Good resource though for filters and such. I just buy Yamaha stuff though and the OEM bearings were like $20 each list. If you have YES you might ask your dealer for freebies. They are a bitch to get them out, harder than a Strom of course. I did a buddy's but not mine, had a hard time moving the collar over to drive the first side out. A blind collet-type puller would be much better.
post #10 of 51 Old 12-18-2018, 11:19 PM
Brockie's Avatar
I would be sure that the number is 6004DK.
All the wheel bearings that I have ever used are inscribed with the bearing number (not the part#) on both sides of the outer race so that you can remove the seal to examine the wheel for the bearing number before removing them. Note that the numbers are very small.
The two letters are also indicative (I vaguely remember DS as meaning double sealed, which is what you want. So the D means double sealed and the K is some other indication of the construction or use of that bearing.
With those four numbers you can walk into any bearing supplier and order them, not forgetting to add that you would prefer double sealed.
Japanese manufactured bearings have always had a better reputation. Also more than a few times SKF has been recommended to me by people whose opinions I respect.
Brockie is offline
Ugh, right wheel bearing imploded. CruisnGrrl DL1000 from 2002-2012 23 04-18-2016 08:56 AM
Premarure front wheel bearing failure, 6k miles mistico DL1000 from 2002-2012 27 11-23-2014 07:57 PM
Front Wheel Bearings. 2 questions garrydymond DL1000 from 2002-2012 5 07-14-2013 10:15 AM
