dl650 2017 - oil/filter change - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 16 Old 10-22-2018, 08:36 PM Thread Starter
Hello,
I'm currently preping my bike for winter storage (quebec/canada). It's my first one and it only have about 650km on it. I've been told it's a good idea to change the oil and oil filter before storing. I'm all ok with that, but I never did that on a car, even less on a bike. I would like to know what tool are required and what I must buy to do this. After, I'll google some video's unless you have good one on how to do it. I'm open to all recommendation, let it be parts brand, model or anything else.
I have a Suzuki V-Stromg 650 SE 2017 (not the XT, it's like the DL650A but it came with both side trunk). I don't have a center stand and it's 1.5" lowered in front and back.
Thank you
nodiaque is offline
post #2 of 16 Old 10-22-2018, 09:57 PM
Asking for a recommended brand of fluids or filters will likely get you a lot of differing opinions, all of which will probably be fine. There’s a thread on here called the only oil thread, or something along those lines. I suggest spending some time and read through the posts ( there are many pages of them) and form your own opinion. Lots of good information there, and as long as the oil meets the specs spelled out in your owners manual you should be fine. There’s also lots of discussions about filters that will help. Changing oil is one of the simplest things on the bike and is easily done by the most novice folks. Don’t be intimidated, there are videos out there that will help. Tools are minimal, and the job can be done in under 10 minutes. Best of luck
Houstrom46* is offline
post #3 of 16 Old 10-23-2018, 12:13 AM
I think some just worry much over nothing, leave the oil be and just fill the tank with gas and fuel stabilizer. Battery tender is a good idea, but not necessary to keep hooked up the entire Winter.
post #4 of 16 Old 10-23-2018, 02:31 AM
Brockie's Avatar
It is a very simple job, and much more convenient to do it yourself rather than waiting around while you pay somebody to do it for you.
2.75 L of a good 10W-40 MOTORCYCLE specific oil (as autos do not have a wet clutch), a matching oil filter, an oil filter removal wrench, a 17mm wrench or socket, and an oil drain pan.
The book also says to change the oil drain plug crush washer but I do not usually do that and I have never had an oil leak there, nor ever lost a drain plug. Buy a new 17mm crush washer if you like.
Here is a good video.
There are many more. Just google Suzuki V-Strom oil change. All of the various years are essentially identical so far as this job goes.
Here is a good text/photo description. Oil Change Clinic: Suzuki V-Strom (DL650) | RIDERS RECYCLE.com Blog
Myself, I would prefer to wait winter out and do the oil change at the beginning of the new riding season.
Houstrom46* likes this.
Brockie is offline
post #5 of 16 Old 10-23-2018, 03:42 AM
ddphillips's Avatar
Re crush washer, I don't replace this either, but I do use some silastic on the washer surface to help seal without need to over tighten the sump plug, have done the same on all my bikes and cars, no leaks, no stripped sump plugs, when you undo the sump plug the silastic just peels away.
Brockie likes this.
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
post #6 of 16 Old 10-23-2018, 06:04 AM Thread Starter
Tha k you everyone for all the Information, I'll crunch everything to get a head on all of these.
nodiaque is offline
post #7 of 16 Old 10-23-2018, 06:45 AM
In 30+ years of doing my own oil changes, I've never replaced crush washers on any bike or car I've owned. Hi milers were 240K on an Accord I sold a few years back, 180k on the wife's current Camry, and a Silverado & Sierra each with just under 120k miles when I sold them (although I don't think 120k is considered high miles anymore). I owned each since new, and none ever had any leaks from the drain plug. Any thoughts on whether Walmart or any of these fast lube chains bother with the crush washer?
post #8 of 16 Old 10-23-2018, 07:26 AM
spike55_bmw's Avatar
I agree that washers can be reused, but there's a limit
Lrobby99 and snorkie like this.
spike55_bmw is offline
post #9 of 16 Old 10-23-2018, 10:19 AM
Brockie's Avatar
The torque spec for the oil drain plug is 15ft/lbs, not 150ft/lbs.
Highwayman2016 and eff like this.
Brockie is offline
post #10 of 16 Old 10-23-2018, 10:32 AM
Fox
Fox's Avatar
Haha you've got that right.
And if there's a limit for v-strom 650 crush washer reuse, I haven't found it yet. Original crush washer here, 32 oil changes, no visible wear on the threads and no leaks (from the drain plug anyway ).
Brockie and Vindex1963 like this.
Fox is offline
Has Owning My DL650 Saved Money ? XLonDL650 General V-Strom Discussion 48 09-10-2018 11:23 PM
2016-16 DL650 aero vs 2017 Nicad General V-Strom Discussion 0 08-28-2018 07:20 PM
2015 DL 650 Upgrade to 2017 DL650 dare2 DL650A - 2017+ 4 03-21-2018 12:37 PM
2017 DL650 GPS Mount richlandrick AdventureTech LLC 2 03-05-2018 09:54 AM
Oil Change on 09 ABS dl650 bneedles DL650 and DL650A - 2004 to 2011 21 10-08-2011 10:16 PM
