pc-8 install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By SECoda
post #1 of 9 Old 09-08-2018, 08:53 AM Thread Starter
pc-8 install
Hello All,
I am installing a eastern beaver pc-8 and I have a question, can I still attach a battery tender to the batteror do I need to route it though the pc-8 on a unswitched circuit.
Thanks
Durbinator is offline
post #2 of 9 Old 09-08-2018, 09:15 AM
SECoda's Avatar
I have the BT harness/connector direct attached to the battery and zip tied on the frame on both of my bikes. It is not connected through the PC-8 on my V2. It has its own fuse in the harness so no need to go through the PC-8. You can charge the battery or use the power from there in an emergency. It's only the covered connector sitting there. Why waste a circuit on the PC-8 and double fuse it.
Big B likes this.
SECoda is offline
post #3 of 9 Old 09-08-2018, 09:52 AM
Solo Moto's Avatar
Yup, either way or both together works. I had the fused battery tender pigtail direct to battery, plus a Powerlet socket connected to an unswitched Eastern Beaver PC8 circuit on my '14 Vee 2. Used that with a (Powerlet to SAE) adapter for the battery tender and air compressor, or direct plug in for my heated vest, etc.
Current: '17 R1200GS Adventure, '16 DR650SE, '15 DR200S
Past: '14 DL1000A ADV, '07 DL1000, '01 K1200LTC, '89 ZX10, '81 KZ650, '75 DT400B
Solo Moto is offline
post #4 of 9 Old 09-08-2018, 10:19 AM Thread Starter
Thanks for the replies I think I'll connect the BT to the battery and run the others thru the pc-8.
post #5 of 9 Old 09-08-2018, 11:13 AM
this is how i have mine also^^^^^^
brutalguyracing is offline
post #6 of 9 Old 09-08-2018, 12:16 PM
Stalky Tracker's Avatar
Originally Posted by SECoda View Post
I have the BT harness/connector direct attached to the battery and zip tied on the frame on both of my bikes. It is not connected through the PC-8 on my V2. It has its own fuse in the harness so no need to go through the PC-8. You can charge the battery or use the power from there in an emergency. It's only the covered connector sitting there. Why waste a circuit on the PC-8.
I'm with SECoda and that's the way mine is done too.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is online now
post #7 of 9 Old 09-08-2018, 12:20 PM
SECoda's Avatar
We are in the raining remnants of tropical storm Gordon so the riding day is shot. :-(
SECoda is offline
post #8 of 9 Old 09-08-2018, 02:43 PM
I have my BT pig tail connected to one of the unswitched terminals on my PC8, and zip-tied it to the frame almost exactly the same way SECoda has it on the pic above. I already have the PC8 & my horn relay directly on the battery, so for me, I already had a jungle of wires from the battery and the whole reason I got the PC8 was to clean it up a little.
Houstrom46* is offline
post #9 of 9 Old 09-08-2018, 05:50 PM
blaustrom's Avatar
I also have my BT pigtail connected directly to the battery.
NOTE: If you use a compressor to fix a flat and connect it via the BT pigtail make sure to up the fuse to 15A. The compressor will blow the stock 5A fuse how do I know?
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
Bridgestone BWs install Ago DL1000A - 2014-2016 10 01-12-2016 06:28 PM
SW Motech Skid Plate - V2 Install Question Vaseface DL1000A - 2014-2016 10 01-01-2016 04:02 PM
GStrom DL650AL3 2013 Front Fairing Cowl Install / Removal TheSheep DL650A - 2012-2016 1 12-25-2015 08:49 AM
Oxford Heated Grip install on Pro Taper Contour ATV High Bend Craftsman13 Maintenance, Tech and Products. 12 04-03-2014 10:23 AM
SV Racing Frame and Swingarm slider install PICS! (On an Adventure w/ Crash Bars) Pele2048 DL650A - 2012-2016 5 11-12-2013 07:22 AM
