Adjusting Chain Tension - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #1 of 53 Old 07-15-2018, 01:31 PM Thread Starter
LL Fauntleroy's Avatar
So all the online how-to-videos show the chain tension adjusted with the rear wheel in the air, which makes sense, to help find the tight spot on the chain, easier to site the alignment once adjusted and clean while your at it. While the manuals state needs to be on the side stand.
So what should the slack be with the rear wheel up, how much do you add to the manuals .8 - 1.2 inches while on the side stand?
LL Fauntleroy is offline
post #2 of 53 Old 07-15-2018, 01:50 PM
Real easy--put the rear in the air for cleaning and lubing, check and adjust while on the side stand as per the manual and be done.
My bikes are set to 20-30mm.
Grimmer likes this.
MAZ4ME is offline
post #3 of 53 Old 07-15-2018, 02:05 PM
Grimmer's Avatar
This is how I do it. If you have tight spots you can either roll a few times and check tension at multiple places, or find the tightest spot on the center stand and then adjust at that spot on the side stand.
But to answer your question, you could try measuring a given spot on the side stand and then measure that same spot again on the center stand to get the offset for your bike. An average of multiple sample points would be best.
I think I recall reading some threads with general recommendations but I can't remember for sure what it was, seems like it was about 1/2" or less. Don't quote me on that cuz it could be completely wrong. Personally, I would measure the offset for myself, given what is at stake.
A little loose is better than a little tight. Mine is currently running at the loose end of the spec and I've been procrastinating the adjustment...
SECoda likes this.
Grimmer is offline
post #4 of 53 Old 07-15-2018, 02:07 PM
Grimmer's Avatar
Some bikes are specified with the wheel off the ground. Suzuki doesn't supply the V-Strom with a center stand so they specified it on the side stand.
Measurement and specificstion needs to match the procedure.
Grimmer is offline
post #5 of 53 Old 07-15-2018, 02:49 PM
And dont put your blind faith in factory swingarm marks either.
VSrider likes this.
MAZ4ME is offline
post #6 of 53 Old 07-17-2018, 03:34 AM
Gert's Avatar
What I have found works well for me, when at home, is a swing-arm stand. Makes cleaning and lube easier knowing that the bike is safely supported. Once the slack is correctly set via the swing-arm stand, you now can determine the amount of slack required for the side and center stand adjustments more accurately. Note that you can even make use of mike crates / car trestles / suspend from rafters / etc, as a swing-arm stand but I can't say that it will be as secure as a proper swing-arm stand.
Gert is offline
post #7 of 53 Old 07-17-2018, 03:39 AM
jmf552's Avatar
I follow an online video that recommends using calipers rather than the marks. I put the bike on the center stand, find the spot on the chain with the most play, set it to 1", use calipers to make sure the distance is the same on both sides, torque the nuts and finally recheck the spacing. I ignore the marks.
jmf552 is offline
post #8 of 53 Old 07-17-2018, 04:43 AM
What are you measuring relative to? From what I have seen, most people's use of calipers (whether vernier or otherwise) is pretty poor. I would think that the alignment marks are less out than what you would get from poor caliper use. But I haven't verified for myself as to how accurate the marks are. At least you shouldn't have the issue I had with my first ever chain adjustment on an old bike, where torquing up the wheel would pull the wheel out of alignment.
rambaldi is offline
post #9 of 53 Old 07-17-2018, 07:50 AM
VSrider's Avatar
Inch and a half slack on center stand, the eleventh commandment.
Spec and VstromGrin like this.
VSrider is offline
post #10 of 53 Old 07-17-2018, 09:28 AM
blaustrom's Avatar
Measuring with the caliper is difficult, at least for the V2, since there is no good way to measure the actual axle position, just the adjustment spacers, and they have play on the axle.
I did verify that the markings are accurate, when measured from the machined end of the swingarm. But that assumed that the machined ends are accurate and perpendicular to the chain. Don't know if they really are.
Big B likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
