Rostra CC Wiring Diagram and dipswitch settings for DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-28-2009, 12:00 AM Thread Starter
Basso's Avatar
Wiring Diagram. If you don't have the switch with the engage light or don't care about it, you don't need that relay. If you want to use it, this does work:
Using the same stuff as larolco
cruise control #250-1223: http://www.brandondist.com/products/cruise1223.htm
switch #250-3592: http://www.brandondist.com/products/Univ_switches.htm
Dispswitch settings. These settings offer a mild surge on set, but otherwise its pretty smooth. I am happy with these settings and will not be changing them.
BTW, one thing to consider if installing the rostra is the power draw. When the motor is pulling the throttle cable, it is using additional power, so if you run anything beyond heated grips and the CC, get a voltmeter and don't let it dip into the 12s.
[SIGPIC][/SIGPIC]Bikes: '08 Suzuki Bandit 1250 ABS; '07 DL650 ABS - SOLD; '08 DL650 -SOLD; '07 Suzuki M50 - Sold
IBA# 33667
Basso is offline
post #2 of 6 Old 04-16-2019, 09:57 AM
Dread7's Avatar
Considering it works and both clutch and brake disengagement while you are using it I would say it's probably wired correctly. But not all rostras are the exact same model and yours may be newer than the one in the wiring diagram or have updated software.
That being said you may have to ground the blue wire off the rostra unit that is now going to the brown/black wire. It has something to do with a car having a clutch disengagement which the rostra doesn't like. I found a nice write up on a tacoma about it. It shouldn't affect how it works at all except take the clutch disengagement out of the loop.
Here is the article have a look for yourself
https://www.tacomaworld.com/threads/...tacoma.388098/
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is online now
post #3 of 6 Old 04-16-2019, 11:01 PM
Does this work on a 17' Wee ???
Kelrich is offline
post #4 of 6 Old 05-21-2019, 11:28 PM
Anyone know if the 2017+ Wee's have the same wiring colors?
Thanks.
Current ride: 2017 DL650. Previous Rides (all Suzuki except last): 1993 VX800; 1987 Cavalcade LXE;
1986 Cavalcade LX; 1983 GS850G; 1982 GS850G; 1974 GT550; 1972 Yamaha DS7
IBA Saddle Sore 1000
farokh is offline
post #5 of 6 Old 05-25-2019, 09:33 PM
Motor7's Avatar
One way to find out would be go to a oem Suzuki parts seller
(Like Babbits online) and compare wiring harness parts numbers.
But since they deleted the emergency flashers on the 17 I bet it is different.
'15 DL650XT
Motor7 is offline
post #6 of 6 Old 05-30-2019, 11:56 AM
Well, I can answer that question - the wiring is different even though there are colors that are the same.
farokh is offline
