Rear axle nut came off! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 31 Old 08-21-2017, 07:05 PM Thread Starter
Exclamation Rear axle nut came off!
I thought I was feeling a wheel bearing failing. When I checked out my axles I found that the nut and rectangular tab under it were both missing. Pretty scary, must not have been for a long time but still.
Anyway, I want to replace it obviously, and I haven't found many places to get the nut (there is a $48 nut on google marketplace which seems to be the best bet) but even harder is to find the rectangular tab that sits between the nut and the swingarm.
Anyone know where I might be able to find one? or better yet a kit with the washer tab and the nut together?
Logidouser is offline
post #2 of 31 Old 08-21-2017, 07:07 PM Thread Starter
The image I attached is something I found online to show what it's supposed to look like.
post #3 of 31 Old 08-21-2017, 07:26 PM
Thumbs up Well....you might try a SUZUKI dealer!
https://www.google.com/url?sa=t&rct=...ZQAGCwNsDGiGCw
Too Fast to be Last!
DL1000 Pilot is offline
post #4 of 31 Old 08-21-2017, 07:26 PM
Not sure which Strom you have, but Oneida is a good source of parts, usually lower priced than elswhere https://www.oneidasuzuki.com/store/c...acement-parts/
Mark
mpom is offline
post #5 of 31 Old 08-21-2017, 09:48 PM
My 04 has a castellated nut and I have a hair clip that keeps it in place.
Originally it had a cotter pin in it.
post #6 of 31 Old 08-21-2017, 10:07 PM
BanditDave's Avatar
I would be having a close look at the thread on the axle. Maybe it is wise to replace the entire assembly.
I would also be checking the front axle and probably do a check of the entire bike.
_________________
BanditDave
Hervey Bay, Queensland, Australia
2015 Suzuki DL650AL5
x 2014 Honda CBR650F
x 2009 Suzuki Bandit 1250
x 2006 Suzuki Bandit 1200
x 2004 Suzuki VZ800 Marauder
BanditDave is offline
post #7 of 31 Old 08-21-2017, 10:25 PM
Have you tried a salvage yard?
Old Time Rider and Logidouser like this.
wingstrom is offline
post #8 of 31 Old 08-22-2017, 01:59 AM
Clayyalc's Avatar
Look on Partzilla. The nut is on the "Rear Wheel" diagram ($13.81) and the plate is on the "Rear Swingarm" one ($3.77)
Logidouser likes this.
2015 DL650
Clayyalc is offline
post #9 of 31 Old 08-23-2017, 03:45 PM Thread Starter
I have not, good call though
post #10 of 31 Old 08-23-2017, 08:08 PM
Make sure you torque that axle nut to spec!! 72.5ft/lbs for my K6.
I noticed I cannot get near that with the tools in the bike's kit as the 24mm wrench is about 4-6 inches long... when I did not torque to spec, the cotter pin kept the nut from spinning off...
Torqued to spec with a new cotter pin is best.
DL650 K6
*Stock*
"...there won't be any money. But when you die, on your death bed, you will receive total consciousness. So I got that going for me... which is nice."
FiSKars22 is offline
