Side Stand Lubrication - Best Practices - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 15 Old 07-05-2017, 01:43 PM Thread Starter
iamsmiling's Avatar
My kickstand has become stiff (I'm thinking it wasn't lubed at installation?). What is the preferred method of lubing the stand pivot, simply squirt it with oil or remove the bolt and lube properly with grease?
iamsmiling is offline
post #2 of 15 Old 07-05-2017, 01:49 PM
I just spray some chain lube all around the pivot area of mine.
V-Tom, chicago, Old Codger and 3 others like this.
post #3 of 15 Old 07-05-2017, 02:08 PM
I've been using WD-40. Seems to be working fine.
kiwi_outdoors and Brockie like this.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #4 of 15 Old 07-05-2017, 02:20 PM
Spec's Avatar
I spray it with some brake cleaner to clean off the gunk.
Chain lube to lube the pivot.
Spec is offline
post #5 of 15 Old 07-05-2017, 02:52 PM
kd70qc's Avatar
I use a spray lithium grease in the pivot point. ~$4 a can from Home Depot or lowes. Put the bike on the center stand, clean associated gunk off of the surrounding area with cleaner of your choice. Spray into the pivot point from the left and right side of the bike while exercising the side stand up and down. Wipe off excess. The grease stays in the joint longer than an oil. I suppose a thick, wax/moly chain lube would work as well.
NyMeTsFaN912 likes this.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #6 of 15 Old 07-05-2017, 04:49 PM Thread Starter
iamsmiling's Avatar
Thanks all. Yet another vehicular project for next weekend.
I've got spray teflon chain lube but the only grease I have requires an applicator (such as a finger . . .)
If I pull the mounting bolt to access the inside of the stand shaft will I have issues with the springs?
I like this because it is clear. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #7 of 15 Old 07-05-2017, 05:03 PM
eagleeye's Avatar
Yes, you will have to figure out how to get them back connected, but it can be done. I used a needle nosed vice grips. and as far as lubing, I'd say anything, as it will get gumed up, washed away and over and over again.
Guess I should ask why you are going to take it apart, hopefully not to lube.
Have fun,
blaustrom likes this.
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #8 of 15 Old 07-05-2017, 05:38 PM
blaustrom's Avatar
Have fun,
A lot can go wrong trying to get that bolt out. I would not touch it unless I absolutely had to. Use the advise given and lube from the outside. It's just a simple pivot and should not need much to make it move.
Brockie likes this.
blaustrom is offline
post #9 of 15 Old 07-06-2017, 12:22 AM
bwringer's Avatar
Crikey, you're overthinking this.
Just spritz it with chain lube whenever you're down there lubing the chain.
bwringer is offline
post #10 of 15 Old 07-06-2017, 09:32 AM
Brockie's Avatar
Don't use pliers unless you feel like getting stabbed with the end of a spring - or lose skin on some sharp motorcycle bracket. Ask me how I know.
If you feel that you HAVE to remove your stand I have in the past replaced the side stand by first connecting the springs and then forcing the pivot end into its recess, then get the bolt back in.
A few weeks back both my stands got a few squirts of WD40. Problem solved.
Brockie is offline
