Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums (https://www.stromtrooper.com/forumindex.php)
-   Maintenance How-to (https://www.stromtrooper.com/maintenance-how/)
-   -   Side Stand Lubrication - Best Practices (https://www.stromtrooper.com/maintenance-how/377785-side-stand-lubrication-best-practices.html)
iamsmiling 07-05-2017 02:43 PM
My kickstand has become stiff (I'm thinking it wasn't lubed at installation?). What is the preferred method of lubing the stand pivot, simply squirt it with oil or remove the bolt and lube properly with grease?
Big B 07-05-2017 02:49 PM
I just spray some chain lube all around the pivot area of mine.
bmwguy 07-05-2017 03:08 PM
I've been using WD-40. Seems to be working fine.
Spec 07-05-2017 03:20 PM
I spray it with some brake cleaner to clean off the gunk.
Chain lube to lube the pivot.
kd70qc 07-05-2017 03:52 PM
I use a spray lithium grease in the pivot point. ~$4 a can from Home Depot or lowes. Put the bike on the center stand, clean associated gunk off of the surrounding area with cleaner of your choice. Spray into the pivot point from the left and right side of the bike while exercising the side stand up and down. Wipe off excess. The grease stays in the joint longer than an oil. I suppose a thick, wax/moly chain lube would work as well.
iamsmiling 07-05-2017 05:49 PM
Thanks all. Yet another vehicular project for next weekend.
I've got spray teflon chain lube but the only grease I have requires an applicator (such as a finger . . .)
If I pull the mounting bolt to access the inside of the stand shaft will I have issues with the springs?
I like this because it is clear. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
eagleeye 07-05-2017 06:03 PM
Yes, you will have to figure out how to get them back connected, but it can be done. I used a needle nosed vice grips. and as far as lubing, I'd say anything, as it will get gumed up, washed away and over and over again.
Guess I should ask why you are going to take it apart, hopefully not to lube.
Have fun,
blaustrom 07-05-2017 06:38 PM
Have fun,
A lot can go wrong trying to get that bolt out. I would not touch it unless I absolutely had to. Use the advise given and lube from the outside. It's just a simple pivot and should not need much to make it move.
bwringer 07-06-2017 01:22 AM
Crikey, you're overthinking this.
Just spritz it with chain lube whenever you're down there lubing the chain.
Brockie 07-06-2017 10:32 AM
Don't use pliers unless you feel like getting stabbed with the end of a spring - or lose skin on some sharp motorcycle bracket. Ask me how I know.
If you feel that you HAVE to remove your stand I have in the past replaced the side stand by first connecting the springs and then forcing the pivot end into its recess, then get the bolt back in.
A few weeks back both my stands got a few squirts of WD40. Problem solved.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
