New Cush Drive Need Help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By Big B
  • 1 Post By blaustrom
  • 2 Post By LL Fauntleroy
post #1 of 9 Old 04-13-2017, 02:32 PM Thread Starter
LL Fauntleroy's Avatar
Take pictures before taking anything apart.....keep repeating........
New cush drive installed 06 wee, there is a 1/4 inch gap, the sprocket assembly should be flush? I can't push it down anymore
LL Fauntleroy is offline
post #2 of 9 Old 04-13-2017, 03:54 PM
Take a rubber mallet to it and ensure the sprocket carrier is going all the way in the hub. New rubbers is a "tight" fit, and that is a very good thing.
realshelby likes this.
post #3 of 9 Old 04-13-2017, 04:40 PM Thread Starter
Thanks B,
But 1)should it be flush?,
2) Should I take it off and add a little lube, if yes, what kind of lube? small amount of tire lube, won't degrade rubber
So close to getting the wheel back on, don't want to mess up now, light at the end of the long tunnel
post #4 of 9 Old 04-13-2017, 06:07 PM
Just make sure everything in the hub area is clean. A bit of Windex won't hurt a thing. Like BigB says, tight is good! After the first time it will be easy.
realshelby is offline
post #5 of 9 Old 04-13-2017, 07:11 PM
Here is how i fit new cush rubbers
On a dr but same principle
brutalguyracing is offline
post #6 of 9 Old 04-13-2017, 07:21 PM
blaustrom's Avatar
Just install the wheel. The axel will push it in that last little bit. Hope you have the spacer in there and correctly positioned. The spacer will determine the final position of the sprocket carrier.
Spec likes this.
blaustrom is offline
post #7 of 9 Old 04-13-2017, 08:04 PM
STCorndog's Avatar
I hate to force them since its scrubbing the rubber surface. I use a little silicone spray when I do them.
STCorndog is online now
post #8 of 9 Old 04-14-2017, 01:44 PM Thread Starter
Ended up rubbing a small amount of tire lube on the metal of the sprocket metal hubs that fit into the rubber cushing.
Good cleaning on both sides...back the road today
Big B and vinnyvavoom like this.
post #9 of 9 Old 04-17-2017, 11:38 AM Thread Starter
So sprocket carrier final is app 1/8" proud of the wheel receptacle, this good?
