Driving shaft bearing cover torn - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 12-06-2016, 03:04 PM Thread Starter
While in the process of replacing the driving shaft seal behind the sprocket we managed to damage the bearing cover ,,,what now,,,,can we leave it like that will there not be oil pissing out.
File Type: jpg WhatsApp Image 2016-12-06 at 21.37.19.jpg (10.3 KB, 67 views)
Patrol is offline
post #2 of 11 Old 12-06-2016, 09:09 PM
I will wait and see what Greywolf says, but IMHO that is not good at all.
Picture is pretty small, but from what I can see you might not be happy with what you will be told. To get the seal out, all you do is barely insert 2 small sheet metal screws and take a couple sets of pliers and pull out the seal, mine came out without any issues.
post #3 of 11 Old 12-06-2016, 10:17 PM
Right. You need to replace that seal.
post #4 of 11 Old 12-06-2016, 11:19 PM Thread Starter
I understand the seal replacement is necessary and that is already removed,,,
the bearing that is in the housing came as a standard (part nr: 25x62x1) indicates one side is closed ....that is the part that got damaged ...do I have to replace that complete bearing
Patrol is offline
post #5 of 11 Old 12-06-2016, 11:28 PM Thread Starter
I enlarged the pic..
Patrol is offline
post #6 of 11 Old 12-07-2016, 12:18 AM
So you replaced the original plain bearing with a bearing that is sealed on one side. You can remove the rubber part of the new bearing and the seal you add on top of that will hold back the oil.
post #7 of 11 Old 12-07-2016, 12:38 AM Thread Starter
Eish I struggle to get through to you guys..LoL
Nope that is still the original bearing, I am worried that the engine pressure would be too much for the O ring in the sprocket spacer and the drive shaft seal...due to the damaged front part on the bearing...
Do I need to worry or can I leave the bearing as it is
Patrol is offline
post #8 of 11 Old 12-07-2016, 01:04 AM
So you are asking if you can leave a damaged bearing alone and not suffer any problems? Do I have that right?
Can tell ya for sure I wouldn't leave it.
How did you damage it?
Tom R
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #9 of 11 Old 12-07-2016, 06:50 AM
I wasn't aware the original bearing was sealed on one side. You can't leave it like that. If you get a new bearing, you can probably remove the seal and put it on the old bearing. It would be very difficult to get the old bearing out. Is it a 650 or a 1000?
post #10 of 11 Old 12-07-2016, 05:07 PM
Rolex's Avatar
I have opened up quite a few gearbox's and this is the first bike I have seen with a sealed bearing in that position.
If it were my bike I would remove the damaged inner seal, replace the outer seal and keep a close eye on things. (oil on the tire)
You will be no worse off than you are now and you could be concerned about nothing.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
