Wiring newbie - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
  • 1 Post By 568v8
  • 2 Post By NVDucati
  • 1 Post By Sgt Schultz
  • 1 Post By greywolf
post #1 of 7 Old 11-14-2016, 03:41 PM Thread Starter
Wiring newbie
Hi, I'm new to biking and especially bike maintenance and am looking for more of a tuition than advice really. I've bought a USB power point to go on my 2012 glee that I want to be live when I've got the key in and the bike lights on but before I've actually started the ignition. What do you suggest I attach it to and, more importantly, how do I make the connection? Is it worth putting a fuse board in so I can easily make new connections as needed? Completely new to electronics too, excuse the ignorance but we've all got to start somewhere right?
tdsmithuk is offline
post #2 of 7 Old 11-15-2016, 08:18 PM
568v8's Avatar
hot all the time
I'd suggest that you wire it directly to the battery, with a fuse of course, so that it can be used without the key. It will be handy to charge a phone or camera battery when your bike is temporarily parked, like a restaurant during lunch, and you don't want to leave it parked with keys in the ignition. Add a simple on/off switch if you want; but wire it so it's hot all the time.
tdsmithuk likes this.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee and finally has touched all of the 48 contiguous United states and the 10 Canadian provinces.
568v8 is offline
post #3 of 7 Old 11-15-2016, 10:55 PM
NVDucati's Avatar
Welcome !
If you are anything like 99% of us, it is likely that you will end up adding more things so your notion of a fuse block makes sense. A lot of folks use one made by Eastern Beaver. There are other brands from places like Twisted Throttle. They all have easy attachment points that are either "switched" or not.
When it comes to installing it you might consider finding a neighborhood bike shop and ask if you can watch.
Sgt Schultz and tdsmithuk like this.
Member: AMA
NVDucati is offline
post #4 of 7 Old 11-16-2016, 02:50 AM
Sgt Schultz's Avatar
Originally Posted by NVDucati View Post
Welcome !
As he said. It's worth your while to fit a fuze block (I have the EB PC eight)that way once fitted you can easily wire in other extras, can be always on or switched. Takes all the connections off the battery terminals.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #5 of 7 Old 11-16-2016, 12:10 PM Thread Starter
So the fuse box runs straight off the battery? I've heard of the Eastern beaver pc8. Are there any U.K. manufacturers of this sort of thing? Hard to find eb products this side of the pond. Thanks again btw. This forum is coming in handy already!
post #6 of 7 Old 11-16-2016, 01:09 PM
Aux fusebox
post #7 of 7 Old 03-18-2018, 09:24 PM
Greywolf has all the answers.
byronlahr is offline
