Small grommets/gas tank - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-19-2016, 07:27 PM Thread Starter
2012 Wee-Strom. Going to try taking the gas tank off. Besides the screws, there are these small pop-off thingys. Maybe 6 - 8 of them on the plastic parts. They're not really grommets. I don't know what you call them. Anyway, I know how to pop them off for removal. You just kinda push down in the middle of them. My question is .....how does one pop them back into place ?? Will it be obvious ?? I'm very stupid. ) ;o) What's obvious to you may not be to me. Will I just push them back in ?
Thanks,
Dennis
hoopdc is offline
post #2 of 4 Old 08-19-2016, 07:42 PM
trapperdog's Avatar
Thanks,
Dennis
Push pins.
https://www.stromtrooper.com/maintena...vets-work.html
If you've never used them they can be confusing
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #3 of 4 Old 08-19-2016, 11:09 PM Thread Starter
Perfect !!! Thanks Trapperdog !!!
hoopdc is offline
post #4 of 4 Old 08-22-2016, 06:46 PM
I used a nail set to remove them. When they are out- you slide the center section so it is sticking out/ up. Once you reinstall, you push center section so it is flush again. Super easy once you do it.
moglink is offline
