unable to remove bolt on exhaust mount - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 03-19-2016, 08:32 PM Thread Starter
I'm installing the enduro guardian skid plate, and need to remove the bolt that is right below the rear brake that is uses to support the exaust. It just spins...make no progress out. Ideas?
bleazie is offline
post #2 of 19 Old 03-19-2016, 11:19 PM
nvr2old's Avatar
Shouldn't do that, something is stripped. The backside is a threaded piece of metal.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 19 Old 03-19-2016, 11:26 PM
Grind the head off, poke bolt out the back.
yesbut is offline
post #4 of 19 Old 03-20-2016, 12:35 AM Thread Starter
Correct it is threaded piece of metal on the exhaust pipe. It cannot be pushed out the back due to other exhaust pipe on the backside that has limited room.
bleazie is offline
post #5 of 19 Old 03-20-2016, 02:52 AM
Ok, how about grabbing the bolt head with vicegrips & apple tension while turning with the allen key, it might "start" the thread ??
yesbut is offline
post #6 of 19 Old 03-20-2016, 12:36 PM Thread Starter
Tried pulling and twisting with vice grips with no luck. Not sure what is meant / how to use Allen key and apple tension.
bleazie is offline
post #7 of 19 Old 03-20-2016, 01:05 PM
I think he meant "apply" tension. Pull the bolt out while turning it.
2015 650XT
2002 CRF450R
1998 Valkyrie
1997 XR400R
1989 GB500
1986 TLR200
1983 XL600R
1979 RD400 Daytona
1978 CB750K x2
1977 XLCR (my first and only HD and I get one from the AMF years)
1976 R75/6 hacked
1975 RD350
1972 R5 350
VetBwana is offline
post #8 of 19 Old 03-20-2016, 08:45 PM
How're you getting on with this ? I can see it's a bit of a bugger. Have you resorted to pulling the pipes off yet ?
yesbut is offline
post #9 of 19 Old 03-20-2016, 09:47 PM Thread Starter
No progress yet. That will likely be my next step unless I find/hear anything else to try. seems like that may take some time. Will have to look up how to do that. The back pipe seems like I will be a bit of work.
bleazie is offline
post #10 of 19 Old 03-20-2016, 11:38 PM
There may be enough play in the bracket for you to cut the bolt head off, & punch it out the back bending it all sideways enough to clear the back pipe. Given that there's a rubber bush and you'll have to replace the present bolt with a bolt & nut it shouldn't matter if the bracket gets a bit bent & re-straightened in the process.
I'm sort of pleased I went with the Weld 86 plate now...
yesbut is offline
