DL1000 Plastic off/on...my way - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By Wildbillsgarage
  • 1 Post By greywolf
  • 1 Post By PTRider
post #1 of 4 Old 11-06-2015, 11:22 AM Thread Starter
Wildbillsgarage's Avatar
https://youtu.be/cG74qhizg8Y
dechaoz05 likes this.
[SIGPhttp://wildbillsgarage.com/IC][/SIGPIC]
Wildbillsgarage is offline
post #2 of 4 Old 11-06-2015, 01:45 PM
At the 2:11 mark, the grommet in the side cowling is missing. That happens a lot. When installing the side cowling, be careful to mate the parts. A little silicone grease in the center hole will help keep the grommet from being pushed out. This is how it should look. The procedure is also covered at Fuel Tank Removal How to, 650 & 1000
Here is some more detail on the plastic rivets from Plastic fairing rivets (Push pins - pop rivets). How do they work?
post #3 of 4 Old 11-06-2015, 03:14 PM
The plastic push rivets are commonly $6 for a pack of 10 in many motorcycle shops. Some auto parts stores might also have the same fasteners.
CruisnGrrl likes this.
post #4 of 4 Old 11-09-2015, 01:50 PM
Hammerdown77's Avatar
Does that include the two larger diameter ones under the front cowling used by the DL1000?
Livin' the dream
Hammerdown77 is offline
Tags
cowling , dl1000 , fairing , lowers
