How to disconnect clutch linkage to change engine sprocket? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 08-28-2008, 03:06 PM Thread Starter
Corkus's Avatar
Here's a photo of my Wee's engine sprocket. I want to change it and I can't figure out how to get the clutch linkage out of the way. I'm thinking it is not that difficult but I couldn't do it on my first try.
Here's the unedited photo:
Here's the edited photo so we know what parts we're talking about:
So, which is correct of these?
A. Simply remove the barrel connector behind the green dot (if so, how? I couldnt' get it off)
B. Remove Bolt A, Bolt B and the retaining tab
C. Remove Bolt C (I know, a nut not a bolt) and the tab
D. B and C
E. No need to remove the linkage (Doesn't look to be enough room to wrench the sprocket nut off to me...)
F. None of the above
Thanks all.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #2 of 12 Old 08-28-2008, 03:17 PM
Gtown's Avatar
Remove the two 10mm bolts and the spring. It just slips right off then.
[SIZE="2"]"Life's tough, it's tougher if you're stupid."
[/SIZE]
FLAT BLACK #181
K8DL650
Gtown is offline
post #3 of 12 Old 08-28-2008, 04:49 PM
rcacs's Avatar
Yup, exactly
rcacs is offline
post #4 of 12 Old 08-28-2008, 05:36 PM
Rjsurfer
Good info guys, I'm planning on doing the same thing (16t) tomorrow I just received my sprocket today.
What to you use to keep the sprocket nut from turning, do you just keep it in gear and use a little rear brake? That won't hurt the tranny?
rjsurfer
rjsurfer is offline
post #5 of 12 Old 08-28-2008, 06:07 PM Thread Starter
Corkus's Avatar
rjsurfer
I was told by a very experienced 650 owner that he "has someone stand on the rear brake with the bike in first gear as he uses a breaker bar to loosen the engine sprocket nut".
I'm the very cautious sort and I get a little spooked about the possibility of tranny damage if I don't do things exactly right. There are pieces in the tranny that are possible to damage with reverse torque on the engine sprocket nut.
My plan is to have someone stand on the rear brake, and hold the front brake, while the bike is in neutral and the rear tire is blocked against something like a curb. (In my case a stout tool box wedged against a wall.) I think it should work and the failure mode is the rear tire turns - no damage. If it doesn't work then I'll put the bike in first gear but I'd rather not do that.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #6 of 12 Old 08-28-2008, 07:32 PM
A and B will free the unit. C is the clutch pushrod adjuster and locknut. Take care after removing the unit. The inside will fall out of the container easily and needs to be put back in the same place if it comes apart.
post #7 of 12 Old 08-28-2008, 10:06 PM
Gtown's Avatar
rjsurfer
I used an air impact gun so I didn't have to do all that fancy holding. Sorry I can't help.
[/SIZE]
FLAT BLACK #181
K8DL650
Gtown is offline
post #8 of 12 Old 08-28-2008, 11:26 PM
Scarlett Harlot's Avatar
GW
What exactly is it that falls out?
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups. ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #9 of 12 Old 08-28-2008, 11:59 PM
Look at the cylindrical part of #17. It's a cylinder within a cylinder helically splined together. The inner cylinder comes out of the outer one.
post #10 of 12 Old 08-29-2008, 12:14 PM
Godfather's Avatar
Slip a 2X4 through the rear wheel and over the top of the swing arm so it rests on each side of the swingarm. When you turn the nut to losten it the wheel will rotate untill one of the three spokes touches the 2X4 and then stop. You can use a breaker bar if needed to losten the nut without damaging anything.
Flat Black 08' DL650. Lots 0' goodies
Godfather is offline
