2009 DL 650 aux power? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-15-2015, 02:27 AM Thread Starter
Just wondering if anyone knows where the auxiliary power line and/or the heated grip power is on the non-abs 2009's? Or if this has been covered in a previous post? I found a post talking about the later ones 2012+
Ron.partch is offline
post #2 of 7 Old 07-15-2015, 10:21 AM
Vees and Wees only have heated grip power connectors, no aux connectors. They are behind the radiator top shroud and are usually taped to the main harness. Look for a tiny spot of orange on the harness as a bit of the orange/green positive wire usually stays visible. It's usually easier to find if you remove the black plastic boomerang shaped piece under the left side of the fuel tank.
post #3 of 7 Old 07-15-2015, 11:04 AM Thread Starter
Thank you so much!!!
post #4 of 7 Old 07-17-2015, 09:20 AM
Swamp's Avatar
Hey Greywolf, are those connectors on all model year DL650's? I have an '07.
Swamp is offline
post #5 of 7 Old 07-17-2015, 09:27 AM
Heated grip connector, yes. Aux connector, no.
post #6 of 7 Old 07-17-2015, 09:28 AM
Swamp's Avatar
Thank you Sir!
Swamp is offline
post #7 of 7 Old 06-30-2016, 01:01 PM
Location: Now living in Milton, Delaware and in the winter near Sarasota, Florida
What about a 2015 650? I cannot find mine?
Ride till you tire.... Then camp under the stars!
manofsteel1 is offline
