TRAX Locks and Keys - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 12-30-2014, 11:30 AM Thread Starter
adh6501's Avatar
TRAX Locks and Keys
I managed to break both of the flimsy keys that came with my Trax cases. Of course, they don't sell replacement keys for the cylinders I have, but will only sell you a whole new cylinder and key set. However, how do I get the old locks off? I tried drilling one, but it didn't work very well. Any suggestions, or do I need to take everything to a locksmith?
The cylinder number was 192, in the off chance someone has a spare matched key lying around.
'03 Vee
adh6501 is offline
post #2 of 4 Old 12-30-2014, 01:34 PM
dravnx's Avatar
You can buy replacement lock sets from Twisted Throttle. As to getting the bad lock out, can't help you there. It's mechanical and will take some fiddling. You might have to drill the hinge pin out of the latch and then replace the latch (TT has them). I don't have one in front of me to check. Maybe someone else will chime in. I broke a key in the lock and was able to fish the broken part out with some needle nose pliers. Because of my CRS (can't remember shit) syndrome, I have spare keys for everything stashed or hidden everywhere. The replacement key is a Y11. If you can get the old one out, a locksmith can cut you a replacement using the parts.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #3 of 4 Old 08-09-2018, 09:27 PM
Richarddenholm's Avatar
The locks are actually quite crappy as I think everyone knows. I did lose my keys by leaving them in the lock and riding 30 miles across Baltimore. I watched a couple youtube vids on picking locks and with two paper clips, I had mine open in less than three minutes. The locksmith easily made new keys for me when I dropped the lock off.
Richarddenholm is offline
post #4 of 4 Old 08-09-2018, 10:17 PM
Stalky Tracker's Avatar
The locks on my Trax cases are held on with a clip on the back side of the latch. Side it off and the lock comes right out. Don't loose the clip as you'll need it to secure the lock when or if you put it back.
Similar to the "U" shaped clips in this link (at Twisted Throttle): https://www.twistedthrottle.com/lock...SABEgIt8_D_BwE
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
Tags
locksmith , trax
