Removing Tail Light Sockets - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 11-23-2014, 10:53 PM Thread Starter
Hi All:
Really dumb question. Trying to remove my tail light sockets, but cannot figure out how to get the black connectors apart. I know it has to be obvious, but apparently not. What is the trick to getting these apart? I have an 07 DL1000.
Reason being, I'd rather splice my GIVI wiring to the socket than the harness on the left sub-frame, but I guess I can do that as a last resort.
Thanks
Howard
Spring Hill, TN
15 FJR1300, 15 VFR800 DLX, 99 Excelsior Henderson Super X, 91 HD XLH1200 Sportster, 77 Honda CB400F SuperSport, 14 Kawasaki EX300 Ninja
cyclemed is offline
post #2 of 3 Old 11-24-2014, 07:08 AM
andreas's Avatar
Rear brake/tail light disassembly is 'fun' the first time. The two plastic plugs are secured together with a clip, using a flash light you should be able to see where you lift the little clip.
OR ----- you release the wiring ( which you'll do anyway ) , then twist the socket unit. Make sure you do that while holding the plastic and not the wires.
Here's a link to a diagram for your bike.
2007 Suzuki V-Strom 1000 DL1000 TAIL LAMP Parts, 2007 Suzuki V-Strom 1000 DL1000 TAIL LAMP OEM Parts - BikeBandit.com
Hope you don't need to remove the lens itself, this would require the removal of the rear fender !!
FB MEMBER #133 - 2008 Wee
andreas is offline
post #3 of 3 Old 11-24-2014, 09:21 AM Thread Starter
Thanks. It was the lifting the clip I was not sure about. Got the lights out, but could not separate easily.
Thanks again,
Howard
Spring Hill, TN
cyclemed is offline
