Aftermarket clutch lever installation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-02-2014, 08:13 PM Thread Starter
All--
Thanks to my new place being on a hill, mixed with some boneheadedness on my part, I broke off a piece of my clutch lever. I found some good threads on replacing the lever with another OEM one, and some good recommendations on aftermarket ones, but I was wondering if the aftermarket ones install just like the OEM, or is each one a little different? I'm leaning toward the Ride It Moto set.
I'm not terribly handy, but I have to believe this is something I can handle. It was also recommended to me that I have a spare clutch and brake lever on hand on long trips. Any thoughts on that as well?
Thanks all
"Vendela" AKA "The Preying Mantis": 2012 DL1000, Givi engine guards, Givi windscreen with Madstad bracket, Caribou cases, Rich's peg kit...To be continued...
Highest temp ridden in to date: 120
PhxTen8 is offline
post #2 of 3 Old 08-05-2014, 11:26 AM
bwringer's Avatar
It should be very straightforward to install.
Yes, carrying spare levers is a good idea. If the bike falls over in a parking lot somewhere, it's very possible to damage the levers to the point they're not safe to use. I keep a cheapo set of brake and clutch levers in the space under the seat -- they're held tightly together with rubber bands so they don't rattle.
bwringer is offline
post #3 of 3 Old 08-05-2014, 01:27 PM
you can do this easily. I have done it and if I can do it , trust me a slightly trained poodle could.
icnxpln is offline
