Reduce Torgue using a Thread Lube or Locker? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-01-2014, 04:47 PM Thread Starter
oldsport's Avatar
Cycle World's Kevin Cameron is asked "If I Lubricate Threads, or Use a Threadlocker, Should I Reduce the Tightening Torque?"
I guess I've never read the fine print before.
2013 V-Strom 650, 1982 Suzuki GS1100E, 1982 Kawasaki GPz1100, 1974 Honda XL350
oldsport is offline
post #2 of 4 Old 08-02-2014, 12:46 PM
That was interesting. The bit about stretch is true enough. BMW suggests replacing a lot of the fasteners when doing work on the clutch and drive shaft since when tightened they do stretch. One time bolts! I suppose the same is true of other manufacturers. They usually don't mention stuff like that in the owners manual because you are supposed to take the bike to dealer for proper service! Wonder if that pimply kid that does the work has been told about it?
notacop is online now
post #3 of 4 Old 08-02-2014, 02:14 PM
RichDesmond's Avatar
I loved this line: "I must caution you against “torque-wrench worship.” "
Rich Desmond
RichDesmond is offline
post #4 of 4 Old 08-02-2014, 02:55 PM Thread Starter
oldsport's Avatar
These days, I'll bet he has if he's at a dealer. Haven't most been through a tech program? Of course knowing and doing are two different things.
I'm a Kevin Cameron nut. I've been reading him since the '70s including all his books.
oldsport is offline
