tank decals - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 06-29-2014, 08:35 AM Thread Starter
tank decals
Greetings again stromer guys, I am just full of questions here lately. Hope you don't mind one more. How to remove large decals on 2011 gas tank. Thanks and keep on ridin.
beemboy is offline
post #2 of 10 Old 06-29-2014, 09:07 AM
cpd419's Avatar
Careful use of a heat gun and rubbing alcohol, ether, etc for glue. A hot hair dryer might work.
2013 DL650
cpd419 is offline
post #3 of 10 Old 06-29-2014, 09:12 AM
https://www.stromtrooper.com/general-...r-removal.html
post #4 of 10 Old 07-22-2014, 07:17 PM
I removed those awful (sorry guys) decals as soon as I bought the bike.
I grabbed the wife's hairdryer and on a sunny hot day decided to go to work.
Just heat the decal at one point. I also used a new small plastic scraper to help with the work. Once the decal gets hot, very gently scrape with the scraper and lift a corner of the decal. You can use your fingers but the decal may be very hot.
Next start peeling with your fingers. It starts peeling fairly easy, but you have to keep at it with the heat. My hairdryer overheated a few times. Just wait and let it cool down to reset the internal breaker.
The decal peeled off in several small and large strips. I next used a product called Goo-Gone to take off any remaining glue.
All in all it took a couple hours of easy work and 3 or 4 beers.
helotech is offline
post #5 of 10 Old 08-01-2014, 05:08 PM
oldsport's Avatar
After being chided here on the forum for still having the warning stickers in place, I went about removing them.
I used paint thinner from Ace Hardware, heat gun and plastic tool from Harbor Freight. The tool was from the auto body section I believe.
BE EXTRA CAREFUL WITH THE HEAT GUN.
Start slow and hold it back 8-12 inches for no more than 10-15 sec. It gets extremely hot very quickly! Touch the tank to make sure you're not going to burn your paint.
Once the decal is heated a bit, take the scraper and start at the edges and gently scrape it off.
Wipe off the residue with a little paint thinner on a rag. Wash with soap and water. (Goo Gone did not work nearly as well as paint thinner.)
I'd say it took 10-15 minutes to remove both decals.
This shows when it was removed and before I cleaned up the last bits with paint thinner.
2013 V-Strom 650, 1982 Suzuki GS1100E, 1982 Kawasaki GPz1100, 1974 Honda XL350
oldsport is offline
post #6 of 10 Old 08-18-2014, 10:44 AM
bicyclebradley's Avatar
GooGone works well.
I bought some 3M Adhesive Remover (comes in a small aerosol can) - that stuff is miraculous (and also smells like oranges).
Beware the young doctor and the old barber - Ben Franklin.
bicyclebradley is offline
post #7 of 10 Old 08-22-2014, 10:00 AM
I'd stay away from the razor blades and only use a finger nail, my friend scratched up a brand new tank with a blade.
itspossible is offline
post #8 of 10 Old 02-28-2015, 08:13 PM
x2 on the razor blade technique- dont as me how i know
ianwuzhere is offline
post #9 of 10 Old 02-28-2015, 10:43 PM
"easy work and 3 or 4 beers."
I do believe that is referred to as Barley Therapy!
post #10 of 10 Old 05-24-2015, 12:53 AM
ProduceGuy's Avatar
Few months late to the party but I have used a 3M Adhesive Eraser Wheel since my days working in a Auto Collision Shop. It does wonders for pin striping and the goo removal. Many friends ask me how to get rid of the double sided tape after removing trim and badges on their cars, show em this every time. Just be careful not to stay in one spot too long on plastics or fresh paint, the heat will start melting stuff.
ProduceGuy is offline
