DL1000 How to adjust the Secondary Throttle Plates - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 51 Old 01-18-2008, 06:14 PM Thread Starter
No longer riding.
handyhiker's Avatar
Adjusting the STV (secondary throttle valve) has shown to make a difference in the RPM range from just above 1500 to just below 4000. The engine runs smoother and seems to have better response. Also some have reported better fuel mileage and a linier throttle response.
There are two different methods for synchronizing the secondary throttle valves. These procedures will work for both the 1000 and 650 models. Please note that the 650 adjusts from the rear throttle body and the 1000 from the front throttle body.
To access the linkage and adjusting screw, remove the tank and entire air cleaner housing. While there, also check the clamps for the throttle bodies as they have been found loose from the factory.
The valve plates sit slightly open with the engine off. Grabbing the linkage by hand and close the plates, you may notice that the plates are not open the same amount; this is what you are adjusting. By turning the screw just above the TBS screw, the front plate can be moved to more open or closed. The back cylinder is the constant.
There are two ways to measure the difference between the secondary throttle plates.
The first method, is to use a small piece of wire like a spark plug gap checker that is made of different size wires bent in a small "L" shape. Take a pair of pliers and straightened out a few of the smaller ones. Try the .020, .024, .028, .032. Then try inserting the wire between the throttle plate and the air horn while holding the linkage in the closed position. Adjust the screw so that the gap is the same for the front and rear plates. As the gap becomes closer you will need to use different size wires.
The second method is to measure the height of the open side of the throttle plate to the top of the air horn. For this, you will need a depth gauge that can measure very small increments. Adjust the screw so that the front and rear plates are the same measurement down from the top of the air horn while holding the linkage closed.
After the adjustment is made, be sure to paint the adjusting screw so it will not move from vibration. This can be done with nail polish.
Either method will work, it is thought that the second method is the more accurate.
After reassembly, you will need to perform a TBS (throttle body synchronization).
Don't grab the 650 plates and try to move by hand, can't be done without damage. The nut circled in red, in the first photo below, is turned by hand to move the secondary plates. This nut is located on the forward left side of the throttle bodies.)
Below are a few pictures that will help explain the procedure. These pictures are from a 1000 with special thanks to KLRman.
More reading on Secondary Adjustments can be found here.
https://www.stromtrooper.com/forums/s...ndary+throttle
http://11109.rapidforum.com/topic=12...%2Csecondaries
cenksinan and Sentinel308 like this.
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
Last edited by greywolf; 02-13-2013 at 09:55 AM. Reason: Changed STP to STV to fit with Suzuki manual nomenclature
handyhiker is offline
post #2 of 51 Old 01-18-2008, 07:33 PM
Until we meet again
Dirt_Dad's Avatar
Thanks for such a clear explanation. Can we please get this as a sticky?
2019 BMW F750 GS, 2015 XT1200 ES, 2012 Yamaha XT250, 2013 Suzuki DR650
Dirt_Dad is offline
post #3 of 51 Old 01-18-2008, 09:11 PM
Jeff Kushner's Avatar
Absolutely...sticky this.....another of Handyhikers fine work for the good of the group!!
Present only:
My VStrom 1000 K7
Stock bikes: a
purple '74 RD350 in great shape,
'72 H1,
1975 GT550,
All-original 1975 H2 750 triple (purple of course),
Modified bikes:
1974 H2 750(my go-fast), a scary fast & fully ported street machine!
'82 Yam 650 Turbo- running 18PSI, Be sure to be pointed where you want to go!
'75 GT550 built up & ported,
'75- H1 wrist-rocket- HOLY GOD ALMIGHTY!
'75 S1 Kaw 250 baby triple w/ lifted and ported 350cc cylinders/28mm flatslides
To-Restore list: '72 H1, 1-'75 H1, 1974 GT750
Jeff Kushner is offline
post #4 of 51 Old 01-23-2008, 05:14 AM
Send a message via Yahoo to Monterey10
Thanks
That's about the most cool post I've seen this year. So many posts are focused on the PC and the primary throttle plates. I can't wait for the weater to clear so I can try adjusting mine.
Monterey10 is offline
post #5 of 51 Old 01-23-2008, 05:18 AM
Great job Handyhiker, nice, simple and straightforward!
klrman is offline
post #6 of 51 Old 01-23-2008, 01:35 PM
limobob's Avatar
adj
Good job on the pics!! For those of a more sporting nature, I have an alternate adjustment method. Carefully remove the 4 screws that hold the sec. plates & remove the plates. Result: much better bottom end torque and no more adjustments! The prim. TB adj. is still a must, however.
Yellow K3 1000 Cool add ons: Cheap guy cruise control (Cat o ring), ATV heated grips, Little tree pine air freshener
limobob is offline
post #7 of 51 Old 01-23-2008, 04:04 PM
No...you should gain more low end torque with "properly adjusted" sencondary plates in. Plates "out" you get a bigger mid/high rush with no speed or RPM restrictions. I'm pretty sure that I have less low end torque with my plates out, but my bike runs well without them. I may put mine back in and try this adjustment......because I fully believe the folks that have done this with positive results.
Thanks again Ken for taking the time to put this thread together.
post #8 of 51 Old 01-23-2008, 07:22 PM
Great job
Thanks a million
Andy Chesley is offline
post #9 of 51 Old 01-23-2008, 09:39 PM
limobob's Avatar
re
Maybe each individual bike will respond differently to this mod. I just know my V has a lot better throttle response and wheelstands easier than w/ them in. Anyway, I was way happy w/ the results and having one less thing to fiddle with. You can ask Berserker about how fast my V is.
limobob is offline
post #10 of 51 Old 01-23-2008, 09:52 PM
Yes the throttle respose is much quicker "or abrupt", compared to them in. If you don't have a PCIII and racing exhausts, as well as the secondaries out on your Vee......then I know your Vee doesn't run like mine.
Everyone that I have talked to that has adjusted their secondaries, said they are not coming back out. It should should not surprise anybody, that these are out of whack from the factory, because the TB adjustment is one of the very first checkouts that needs to be made. A finely/properly tuned Vee is like a whole new bike.....and things tend to stay pretty well once your dialed in.
