Embarrassing question lower Cowl removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-24-2014, 04:17 PM Thread Starter
OldStromy's Avatar
Ok, so I am no mechanic as I am sure this question will lead you to believe.
I am trying to remove the under cowl (dl1000 K6). The pop fasteners are a PIA how I remove this without breaking them. Also, if I do end up breaking one where can I get more?
Thank you in advance to wise and powerful stromverse of mechanics.
Motorcycle Farkles so far: Center Stand, Givi V46 top case, Madstad bracket, Caribou Pelican 35L Pannier System, Nelson-Rigg cl-1050 tank bag, Powerlet for the tankbag, Sena SMH10, Vista Cruise Control, GIVI Crash bars, Rick's fork brace, Rick's kickstand foot, Rick's rear wheel spacer, Garmin 550
Wanted: skid plate, PCV, PC-8
All that is gold does not glitter, Not all those who wander are lost -- J.R.R. Tolkien
OldStromy is offline
post #2 of 5 Old 03-24-2014, 04:48 PM
Plastic fairing rivets (Push pins - pop rivets). How do they work?
https://www.stromtrooper.com/v-strom-...ource-fyi.html
post #3 of 5 Old 03-24-2014, 05:05 PM Thread Starter
OldStromy's Avatar
Oh wise and powerful greywolf
Thank you!!!
post #4 of 5 Old 03-25-2014, 08:45 AM
Rangemaster's Avatar
Same thing happened to me...I try to keep a couple of spares on the garage if I mess one up..they're cheap.
_______________________
Rangemaster/CRSO
NRA-Certified Instructor
'06 Vee
'14 HD FLHTK
Rangemaster is offline
post #5 of 5 Old 07-03-2014, 10:51 AM
I find that spraying them with a little silicone spray makes the push pin easier to move as well as removing the fastener. Helps to loosen and remove some of the built up grime.
DouginNC is offline
