2007 Wee Warning Flasher light switch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 02-28-2014, 08:17 PM Thread Starter
Hello. I purchased a 2007 Wee last week. The only issue is the flasher switch is stuck. The owners manual doesn't state to pus in or pull out to turn flashers on. I don't want to break switch. Can some tell me do you push in out pull out to turn them on. I think the just need a little lube. Thanks
Evan
evanqueen is offline
post #2 of 4 Old 02-28-2014, 11:57 PM
It's push to turn on. I'll bet the previous owner swapped the two screws in the housing. The shorter one needs to be under the switch. Put the longer one there and the switch will be stuck or damaged.
post #3 of 4 Old 03-01-2014, 01:42 PM
The switch was froze on my '07, also. It wasn't the screw, that was the first thing I looked for. I wound up disassembling it to clean & lube it.
2007 DL 650 with assorted upgrades
Solo is offline
post #4 of 4 Old 03-02-2014, 08:16 AM Thread Starter
Thanks for the reply's guys. I will check both. Previous owner installed cruise control and I wonder if he switched screws??
Evan
