What is this screw? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 02-25-2014, 06:41 PM Thread Starter
RoosterMan's Avatar
What is this screw?
What type and size tool do I need to remove the two screws on the underside of the top triple clamp that hold on the starter key assembly, and where can I pick one up? They look like torx but they also have a stem in the middle, I would assume as a theft deterrent? I need to remove in order to change out my top triple clamp, thanks!
I'm pointing at it with a screwdriver in the photo:
RoosterMan is offline
post #2 of 9 Old 02-25-2014, 07:19 PM
p38arover's Avatar
Security Torx.
I can't give the size as I no longer have a Strom to check.
You'll find a kit in Harbor Freight - that's where I got mine on a visit to the US.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #3 of 9 Old 02-25-2014, 07:21 PM
It takes a T40 Torx security bit.
post #4 of 9 Old 02-25-2014, 07:42 PM Thread Starter
RoosterMan's Avatar
As always, thanks Pat. I figured you'd know...... Heading to Napa in the morning........
post #5 of 9 Old 02-25-2014, 10:53 PM
davesride's Avatar
Also known in the trade as a tamper proof torx! Go figure... make it tamperproof and someone will sell the tool to fit it, not tamperproof anymore!!!!
Some can't...some won't.... I might!
Richland Ricks Fork Brace and Mirror extenders, Stebel Nautilus Horn, Suzuki Centerstand
davesride is offline
post #6 of 9 Old 02-26-2014, 11:56 AM
Stalky Tracker's Avatar
My thoughts exactly.
I picked up a "Craftsman 33-Piece Screwdriver Tamper-Proof Bit Set" for about $25 a few years ago. It covers most of my tamper proof needs. :mrgreen:
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #7 of 9 Old 02-26-2014, 11:59 AM
Torx and especially tamper torx are not a very common set to have in your toolbox, so they are more tamper resistant than most.
post #8 of 9 Old 02-26-2014, 06:34 PM
pipes3k's Avatar
I picked a cheap set up from the local Auto parts store.
Paul Johnson
2008 DL1000 VEE
pipes3k is offline
post #9 of 9 Old 02-26-2014, 06:56 PM
The other two security Torx screws are on the TPS and STPS so make sure any set you get includes the T20 and T25.
