Starter switch replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 01-03-2014, 09:56 AM Thread Starter
Hello and Happy New Year!
My starter switch was going bad for a while now (cutting off headlights at times) and since the winter is in full swing I decided to replace it. The replacement assembly has arrived but I'm not clear how to disconnect the throttle cables from the old one. Do I need to take the handle off the bar? Hopefully someone who did it already or has a repair manual could give me a quick tip...
Thanks!
K7 DL650, Silver
novichek is offline
post #2 of 16 Old 01-03-2014, 10:24 AM
Move the throttle cable adjusters for maximum slack and the barrel connectors can be removed from the reel. If the adjusters at the top of the cable don't give you enough slack, also loosen the engine ends of the cables.
post #3 of 16 Old 01-03-2014, 12:28 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Think I need to do the same on my 1000.
Where did you locate the best price for the switch assembly?
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #4 of 16 Old 01-03-2014, 02:05 PM
Scott E. Bonds's Avatar
The switch can be opened up and the contacts cleaned with a pencil eraser. I did this a few years back and she still starts first push.
Search on method (with photos) that was posted here by blacklab. His bike is a 650 and uses a slightly different part but the method and description was close enough for me to do it to a 1000.
Or replace the switch.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #5 of 16 Old 01-03-2014, 02:21 PM Thread Starter
Unhook barrel connectors from the reel - got it.
I ordered the switch assembly from bike bandit - had a coupon + they give 10% off to AMA members.
K7 DL650, Silver
novichek is offline
post #6 of 16 Old 01-03-2014, 07:27 PM
Stalky Tracker's Avatar
Here's a link to Black Lab's website and posting on cleaning the switch: Start Switch Maintenance | Black Lab Adventures
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #7 of 16 Old 01-04-2014, 09:05 AM Thread Starter
Thanks! I cleaned the switch two or three times. It helps for a while but the problem always returned within 4 or 5 months. Hopefully, the new one will fix it permanently.
K7 DL650, Silver
novichek is offline
post #8 of 16 Old 01-04-2014, 09:12 AM
A permanent fix would be to install headlight relays. That will take the load off the stock circuits.
post #9 of 16 Old 01-04-2014, 09:15 AM
tmcgee's Avatar
You need chemical helper for this application. I use this, you only have to do it once: DeoxIT ģ M260Cp, #M260-C1
tmcgee is offline
post #10 of 16 Old 01-06-2014, 02:36 PM Thread Starter
I do have the eastern beaver relay, looks like the switch was damaged by the time I installed it though...
K7 DL650, Silver
novichek is offline
