Easy and gentle primary sprocket removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 10-16-2013, 02:43 AM Thread Starter
There's more than one way to remove this sprocket. Here is my way to make it easy. Remove the cover, bend the safety washer tab away with a wide blade punch or screwdriver, and then shove a rod/or old screwdriver shaft between the rear sprocket teeth and chain as you rotate the wheel forward which will jam it. Keep it tight while you use an impact wench to remove the primary nut. You won't damage anything at this point because you are changing everything as a set anyway.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #2 of 13 Old 10-16-2013, 10:05 AM
hunt1moore's Avatar
I usually use a rolled up shop rag.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
post #3 of 13 Old 10-16-2013, 10:12 AM
janiceclanfield's Avatar
I just use my hand to hold the sprocket while turning the nut with my fingers.
Jeeze, you guys are sissies!
Here, take the bong. Then try the sprocket again...
:beatnik:
janiceclanfield is offline
post #4 of 13 Old 10-16-2013, 10:56 AM
kitesurfer's Avatar
i put a 2x4 through the rear wheel. i use a breaker bar. no sissy air tools for me!
2012 DL650
U.S. NAVY, RETIRED
kitesurfer is offline
post #5 of 13 Old 10-16-2013, 12:20 PM
That is a much better way to do it, of course I still prefer a buddy to sit atop the bike with the rear brake activated.
post #6 of 13 Old 10-16-2013, 01:15 PM
You have a "buddy"?
Tell us all about him.
Inquiring minds want to know.
You can have the bong after you tell us. :beatnik:
post #7 of 13 Old 10-16-2013, 02:35 PM
bleedgrn's Avatar
I tried the 2X4 trick to, didn't work very well. Had a friend step on the rear brake (as BigB stated) works much better. The wood, for me, didn't bind in well and just jumped around when I tried to break the nut loose. I would not recommend using a metal object such as a screw driver on the back sprocket. Could mess up the teeth fairly easily. Besides, having a friend over while you perform bike maintenance gives you an excuse to drink hoppy beer and brag about your bike farkles. :biggrinjester:
Keep Calm, Fly-fish
L2 Glee White- birthday 17 JAN 13
Farkles last to first: MFW Hwy pegs, Russell Daylong, Givi 3D604 tank bag, Motech Pegs, Madstad bracket&adv windshield, Tuono mirrors, Uclear HBC200 headset, E45 topcase, Cree driving lights w/Motech brackets,14T Sprocket, bar riser, E21 panniers, Stich heated grips/outlet, EB PC8, RR Fork Brace, Kouba link, Barkbusters, SW-Motech Centerstand/Skidplate/Crash Bars.
bleedgrn is offline
post #8 of 13 Old 10-16-2013, 02:48 PM
electric impact works well. no need to jam anything anywhere.
2012 DL650A; daily commuter http://www.flickr.com/photos/[email protected]/sets/72157633330697107/
Sold: 2003 SV650: weekend canyon carver http://www.flickr.com/photos/[email protected]/sets/72157630515234266/
fragile_this_side_up is offline
post #9 of 13 Old 10-20-2013, 02:32 AM Thread Starter
Guess you didn't read the post. You are changing both sprockets and chain as a set so why be concerned about the teeth. That was the point. Once the rod/screwdriver is wedged between the teeth and chain, use an impact or whatever you want to break the nut loose.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #10 of 13 Old 10-20-2013, 02:35 AM Thread Starter
Yep. Did that my first time but it poked holes in a perfectly good shop rag.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
