Headlight adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By greywolf
post #1 of 4 Old 10-15-2013, 01:52 PM Thread Starter
I have a 08 Wee and wanted to know which adjuster moves the headlight higher or lower and which way to turn the adjuster and the same for right to left? Thanks in advance.
coral_snake is offline
post #2 of 4 Old 10-15-2013, 02:10 PM
V-Tom's Avatar
I would have to look at my owner's manual to check. (Haven't looked at my 2006 for a few years.) I do want to say that you should make sure to "sync" the headlights when you are adjusting them.
Basically adjust one by masking or disconnecting the other and then do the same to the other one. Make sure they both are at the same level. After that you can easily keep them in sync by giving both the same number of turns of the nut.
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
Last edited by V-Tom; 10-15-2013 at 03:56 PM. Reason: removed erroneous thought, cleaned up typos
V-Tom is offline
post #3 of 4 Old 10-15-2013, 02:26 PM
The vertical adjuster is below and inboard of the light and the horizontal adjuster is above and outboard of the light. They are right hand thread captured screws. The bottom ones pull the bottom down to lower the light when turned clockwise. The outboard ones pull the light to the outside when turned clockwise. Each pushes in the opposite direction when turned counter clockwise.
ste1001 likes this.
post #4 of 4 Old 10-15-2013, 03:12 PM Thread Starter
Thank you Greywolf, you are always a lot of help.
