New chain prep - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 10-10-2013, 04:13 AM Thread Starter
New chain prep
Here's a new one about prepping a new chain. My last chain(RK) came packaged with a super thick tan colored grease. I installed the chain with this thick grease and regretted it since it threw that crap all over my rear wheel and collected under the primary sprocket cover. Now, I've ordered a new chain(Z-VMX) that I want to clean off the factory grease pre-install. I was thinking about cleaning the chain with kerosene first, drying it thoroughly, and then lubing it with DuPont Chainsaver upon install. From past experience, the thick grease that comes with the manufacturer is so thick that it attracts dirt like crazy. Comments?
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #2 of 9 Old 10-10-2013, 04:55 AM
fortp's Avatar
Why bother, it's much more easy to clean a wheel than a chain.
fortp is offline
post #3 of 9 Old 10-10-2013, 06:50 AM
andreas's Avatar
I wouldn't clean it, if it bothers you that much then just wipe of the excess, then once mounted spray with your favorite lube.
FB MEMBER #133 - 2008 Wee
andreas is offline
post #4 of 9 Old 10-10-2013, 01:00 PM
Or get a shaft drive. I agree with the guys above. It's part of having chain drive. The flip side is it's easier to change gearing, cheaper to repair, & transmits more power. Replace all three as a set, otherwise you'll have accelerated wear.
Don't fret over it, just clean it once a year, it's a V-Strom, right?
2007 DL 650 with assorted upgrades
Solo is offline
post #5 of 9 Old 10-10-2013, 01:30 PM
Scott E. Bonds's Avatar
This is a valid question. The tan assembly lube should be removed as you have figured out. But only due to dirt collection and fling off. Your cleaning and relube is just fine. I cheated some and just removed as much tan crap from the chain plates as a rag with WD-40 would remove quickly by wiping. The rest around the o-rings and in between the plates I left on the chain and then lubed the chain the frist time around 100 miles.
I do not clean chains other than the first tan crap removal.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #6 of 9 Old 10-14-2013, 02:26 AM Thread Starter
It's just as easy to clean the new chain pre-install as it is to clean a wheel. A little kerosene and a brush, and it's clean. Plus, I avoid that greasy gunk that builds up under the primary sprocket cover.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #7 of 9 Old 10-16-2013, 12:51 AM Thread Starter
BTW....when one first removes the primary drive cover to perform a clutch adjustment, do you see considerable gunk build-up in this area? The reason I ask is that when I bought my '06 used 3 years ago and did my first clutch adjustment, there was an incredible amount of crud around this area.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #8 of 9 Old 10-16-2013, 04:49 AM
fortp's Avatar
Yes, normal. Better have this than a rusted chain.
fortp is offline
post #9 of 9 Old 11-07-2013, 08:23 PM
I would use diesel fuel and not kerosene, for kerosene can damage and make o ring brittle in the long run.
kartl is offline
