need help! Bike will not start again. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-22-2013, 10:26 AM Thread Starter
Here's the story...
In April my Wee just stopped running. I thought it had something to do with my ABS system, while I was riding that light(ABS) came on and then my gauges cycled like they do when I start my bike. Brought it to the shop and the mech checked out and he checked the stator out and it was burnt. After he replaced it the Wee leaked oil out the wires. The stator was after market and apparently the rubber plug had more holes then wires in it. fixed that issue. Then last Saturday, while I was riding... Bam! my wee decided it just did not want to stay running. Jumped her, but would not get over 5000rpms, bike would die.
I dont have the $$$ for another mech visit. is there a way I can check the Stator without taking the cover off? what else should I try looking at?
I am not much of a mech, but I guess I should start! this old girl is starting to drain the purse.
If any one can direct me in a direction please help, before i pull the stator cover.
The Wee is 2011 ABS with 21,000. No farkels & no extras on the elect. system (GPS, elec grips.) still stock.
G8RNAV is offline
post #2 of 11 Old 07-22-2013, 11:04 AM
Aftermarket stators are famous for being short lived, much worse than the iffy enough OEM ones. Charge the battery to get some working time. Start the engine and put a voltmeter on the battery terminals. You should see 13.5V-14.8V but I'll bet you don't. What guarantee does the shop provide for its work?
Since the stator problems I've seen all happened near the top, I make sure my oil level is always at the full mark to provide as much cooling as possible.
post #3 of 11 Old 07-22-2013, 11:13 AM Thread Starter
the shop treats me good... but this will be the second time i will be in there for this problem. The wifey is pissed and has lost faith in them. I am ready to throw in the towel with them also. I dont think they would have an issue if I brought it back. I just dont want to fork out any more $$$ to them if they are not fixing the whole problem.
I did the battery check, and the battery is dead. it's on the charger now as we speak. Hopefully after work I will put it back in and give it a go.
What else could I check to see if it the Stator, the R/R, or just a bad battery?
G8RNAV is offline
post #4 of 11 Old 07-22-2013, 11:35 AM
Assuming the battery takes a charge, report the voltmeter readings on the battery with engine running and not running. We'll take it from there. If you can't start the engine after having the battery on the charger, replace the battery.
post #5 of 11 Old 07-22-2013, 04:28 PM Thread Starter
Here are the readings:
On the bench: 13.25
on the bike/hooked up:13.25
Started: 12.28
Put it in gear, bike died when releasing the clutch. No power above 2000rpms
cannot do the charging test like in the DR. V-Strom vid?
What now?
G8RNAV is offline
post #6 of 11 Old 07-22-2013, 04:40 PM
kiwi_outdoors's Avatar
spark
take out one good spark plug, reconnect it connected to its spark plug wire. Put an old plug back inthe cylinder head.
Start engine - use insulated pump pliers or similar to hold the removed plug body to engine body - does spark look healthy?
There are other ways to do this stest - but you get what I mean.
kiwi_outdoors is offline
post #7 of 11 Old 07-22-2013, 05:05 PM
The battery is good. The charging system is bad. Almost certainly, 99%, it's the stator. If you need to check for sure, test any 2 of the three yellow or black wires from the stator. Each pairing should provide over 60VAC.
post #8 of 11 Old 07-22-2013, 06:14 PM Thread Starter
I will check that when I get to work in the morning. I will let you know what I find out.
G8RNAV is offline
post #9 of 11 Old 07-29-2013, 12:33 PM Thread Starter
Here is the rest of the story...
SO, after doing the checks as suggested by Greywolf, the stator was the issue once again. I had the bike towed back to the house from work, and after talking to my mech., they came and picked up the bike. After they did what they do, they came to the same conclusion! THE STATOR, again! Mind you all this is the second one within nine months. Now after reading this forum when the stator went up the first time, I made sure my oil was just a bit higher then normal to disperse the heat of the coils. The mech at the shop found the problem to be the R/R. The stator was fried but some how the main culprit was the R/R.
Anyway, they are covering all the labor new Stator, gasket, I'll be on the hook for a new R/R minus labor.
Thanks for all you help with my charging issues.
G8RNAV is offline
post #10 of 11 Old 07-29-2013, 12:44 PM
They're guessing. Believe me, the problem was the aftermarket stator. There isn't a good one out there.
