Fork Oil - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 16 Old 09-25-2013, 09:44 AM
ezrdr55's Avatar
Originally Posted by jeff_connors View Post
"easier to buy" Right! Just ask the auto parts guy for fork oil. He looks like a cow looking at a new gate.
Anyone recommend where to buy fork seals?
I got my fork seals from Motosport.com. You have a choice of All Balls or OEM. I ordered both and just did receive my order so I haven't had time to evaluate which one I will use. I also got new fork bushings. I also use synthetic ATF.
EZ-RDR55
The opinions expressed herein are mine, and do not represent that of any other humanoid past, present or future on this or any other planet.
'95 H-D FXDWG
'06 Honda CRF250X
'04 KTM 450EXC
'97 Honda XR-600R (Sold)
'04 K1200LT (Sold)
'07 K1200GT (Sold)
'09 Wee-Strom DL-650ABS
'14 WR250R
ezrdr55 is offline
post #12 of 16 Old 09-27-2013, 03:35 AM
The last set of All Balls fork seals that I saw were VERY similar to Leak Proof brand seals. AKA no metal spring, and "Leak Prone." I would fit either OEM or Parts Unlimited seals with a true metal spring. I've installed probably 300 sets of Parts Unlimited seals and have yet to have one come back due to a premature leak. OEM is always your best bet, but most people don't want to pay the OEM premium.
Can you post a picture of the All Balls seals that you ordered? I'm interested to see if they have changed their seal design.
2009 WR250R
2004 DL650
1978 KZ650
1966 CB160
1964 CA95
Noobens is offline
post #13 of 16 Old 09-27-2013, 09:55 AM
ezrdr55's Avatar
I'm leaving for vacation, but as soon as I get back I'll be changing the seals and will post some pictures. Thanks for the heads up on the All Balls. FYI - my OEM seals are not leaking but I'm going in there to replace the bushings and that dust cover is all weather checked so I thought I'd just replace that and the seals too.
EZ-RDR55
'95 H-D FXDWG
'06 Honda CRF250X
'04 KTM 450EXC
'04 K1200LT (Sold)
'07 K1200GT (Sold)
'14 WR250R
ezrdr55 is offline
post #14 of 16 Old 09-27-2013, 10:26 AM
Sagebrush's Avatar
For OEM parts I've used Xtreme Powersports lately, they have the same prices as cheap cycle parts, but they ship USPS Priority for "free". So, its a slightly better deal on smaller orders.
I recently ordered the oil seals and the dust seals for the DL1000. I going to put new springs in and figured it was a good time to do new fork seals. My used bike was leaking a good bit, I cleaned them with good results. About 90% of the leaking stopped but the right leg is a bit too wet still.
I've used both ATF and fork oil, either works if you don't need a heavier oil. You can also use hydraulic oils, Hyguard etc. I went with PJ 10 wt this time since I was ordering parts anyway.
Sagebrush is offline
post #15 of 16 Old 11-09-2013, 08:23 PM
I would only go with OEM fork seals.
For whatever reason, they have less stiction than aftermarket.
Crickle is offline
post #16 of 16 Old 11-09-2013, 08:53 PM
Sprocket's Avatar
I bought a set of All Balls seals (Ebay) that included oil and dust seals because I needed to replace the dust seals and the kit cost about the same a one OEM dust seal. I didn't replace the oil seals, but the dust seals were fine, if a bit shorter than OEM. The oil seals do have metal springs in them, 2 springs in each seal.
Sprocket is offline
