Routine maint. clutch adj? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By greywolf
post #1 of 6 Old 06-17-2013, 11:09 PM Thread Starter
Last night, while doing some routine maintenance, I did the clutch adjustment. However, where I get a little iffy is how the manual describes that you loosen the lock nut, tighten down the adjuster screw 'until it stops'. As I'm turning in the adjuster screw, I can feel it getting harder and harder, but not sure exactly how tight I should go 'until it stops'. What I finally did was to tighten the screw until it got pretty firm to the feel and then backed off 1/4 turn. Being the persnickety guy that I be, it has been at the back of mind if I did this correctly. The clutch works just fine.....good strong engagement with no slipping or funny noises or feel. Should I have cranked down on the screw until it got really tight, which would have been truly 'until it stops' tight? ...did I get it right by turning the screw in until it got quite firm?
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #2 of 6 Old 06-17-2013, 11:43 PM
kiwi_outdoors's Avatar
I say yes
I adjusted mine the other day- to me there was a distinct difference between pushing hard and not really pushing on the pushrod
its a funky wee mechanism for sure
kiwi_outdoors is offline
post #3 of 6 Old 06-18-2013, 12:19 AM
"Stops" is a bad word. The adjuster hits the clutch release push rod and then starts separating the plates. Back it off until it turns freely. Then turn it in lightly until you feel resistance as the adjuster meets the push rod. . Then back it out 1/4 turn. Hold the adjuster in that position with the screwdriver as you tighten the lock nut.
hosepd likes this.
post #4 of 6 Old 06-18-2013, 12:44 AM Thread Starter
That's what I expected to feel, but didn't. I think now that part of the solution is to clean the area free of the built-up chain lube gunk that may have added to that premature firm feel. I cleaned some of out by using a big flat screwdriver but it was far from being clean.....and I didn't remove that spiral thingie which could have given access to the rod which is caked with gunk. I just didn't have time as this was the last task and it was after 1AM.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #5 of 6 Old 06-18-2013, 12:49 AM Thread Starter
Thanks Pat. As I was working the screw in and out, I watched its effect upon the rod and the arm that the cable attaches to. From your description, I am confident that I can get it adjusted correctly and sleep better than I did last night. As it is now, I think it is probably adjust a little too tight. I certainly don't want it slipping slightly as I ride and suddenly have no clutch!!
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #6 of 6 Old 06-19-2013, 12:38 PM
First be sure there is plenty of slack in the cable. Re adjust the cable free play after doing the actuator adjustment.
Solo is offline
